Rear Shock Replacement 2009
Old Aug 24, 2015 | 10:43 PM
bigsmitty's Avatar
Hi everyone, had my 09 about three weeks now and looking to replace the rear dampers. I was under doing the oil the other day and it looks fairly straightforward (plus I have the electronic service manual as a guide). Any advice or heads up? I'm reasonably competent, done a fair bit of mech. work but definitely no expert...Thanks and cheers-this has already been a great place for tips and tricks.
Old Aug 24, 2015 | 11:50 PM
xxryu139xx's Avatar
yes its pretty easy.
if your doin straight OEM replacement, you are good to go.
if you decide to get aftermarket like Koni, Bilstein etc. U will have to remove the dust boot from the OEM. you will need to dremel out the nub that keeps the spacer down.
Old Sep 2, 2015 | 06:22 AM
bigsmitty's Avatar
Thanks for the info, it looks pretty straightforward. Probably going to just do OEM replace for now. Try and switch it out when I put winters on and bleed brakes, under the car day...Cheers
mrphilip
May 17, 2017 08:55 PM
ralphch
Jan 7, 2017 11:10 PM
GD3_Wagoon
16
Apr 8, 2010 03:08 AM
blackdot_fit
May 16, 2008 05:05 PM
fiat20
Dec 8, 2005 07:37 AM
