Back door won't unlock (2009 Fit)
Old Nov 24, 2015 | 03:41 PM
Fitman09's Avatar
About a month ago my driver-side rear door stopped unlocking. I can't unlock it manually or with the fob. If I press the unlock button on the fob, the interior manual lever seems like it's trying to move, but it won't budge.
Anybody else had a similar issue? How did you fix it?
Old Nov 24, 2015 | 06:27 PM
dwtaylorpdx's Avatar
You can have this happen when the lock mechanism sticks. Liberal use of a spray oil with the little tube into the mechanism by putting the tube past the window got me in a car that had the look stuck once..
Old Nov 30, 2015 | 01:13 PM
teamkitty's Avatar
The door lock actuators on this car are garbage and all break prematurely. I had my driver's door lock replaced last year and currently have a broken passenger door lock, one broken rear door lock, and a broken hatch lock. Some of the fanboys around here insist they only break because of user error (holding the handles when pressing lock/unlock), but that's a load of crap. Sorry and good luck.
Old Nov 30, 2015 | 05:01 PM
the 09 that i traded a while back had a bad corrosion problem on the gate lever. it wouldn't unlock nor lock. i sprayed liberal amounts of WD40 and it was fine for 7-8months, but had to re-apply. my '12 GE is fine still..
teamkitty
Jan 24, 2021 09:33 PM
arkansasfit
Sep 15, 2019 04:37 AM
adamnnn
Nov 13, 2018 10:25 AM
09Fitter
Jan 14, 2015 02:12 PM
overkil6
Dec 2, 2010 05:12 PM
