passenger window issues, advice needed
Old Dec 1, 2015 | 09:00 AM
Santiad's Avatar
So recently I noticed my passenger side window was responding slowly to the switch on the drivers side. Today I parked aND while sitting in my car heard a "ticking sound" coming from the door. I checked my switch and noticed that while it presses down finex there is no tension when pulling up, like it collapsed beneath the switch.
Thing is, the window is now unresponsive to the passenger side switch now. I have pressed the window lock button until I can get more info on how to resolve this to prevent the motor from burning out .
Any advice or direction on this would be appreciated. I'll be checking the repair manual later today as well. Hope it is just a switch and not a whole assembly that needs replacing.
Old Dec 1, 2015 | 10:43 AM
Santiad's Avatar
update
got out of the gym and checked the drivers switch, and it seemed flushed and "felt" right.....window working again, though I'm hesitant to keep using it....
Old Dec 7, 2015 | 11:41 AM
Isaac513's Avatar
So was it just the window lock button that was depressed? I did that once... and proceeded to take off the entire door panel only to realize that mine was depressed too...
Old Dec 7, 2015 | 12:34 PM
Santiad's Avatar
Nope
No. I pressed it in to cut off the signal being sent from the collapsed switch. Latet on in the day I pressed the switch and pulled on it and found tension returned , so I unlocked the windows.
Old Dec 8, 2015 | 08:48 AM
Isaac513's Avatar
Oh, my bad it was a stuck window switch! Hope it hasn't happened again since.
fitowner10
Aug 22, 2016 09:53 AM
awsiany
Oct 27, 2014 09:25 AM
Body2Big
Jun 16, 2014 03:14 PM
Codger01
Jun 1, 2013 09:13 PM
Satchel
Jan 23, 2009 03:47 PM
