Day time running lights
Old Jan 24, 2016 | 09:34 PM
Irish's Avatar
What's up everyone. Quick question about the daytime ruining lights, is there a way to disable them so that they aren't on unless I turn the headlights on?
Old Jan 24, 2016 | 09:49 PM
345ge8RS5mt's Avatar
There is a way but you might want to consider just running it independently if that's the case
Old Jan 24, 2016 | 09:59 PM
Irish's Avatar
What do you mean by run them independently
Old Jan 25, 2016 | 02:03 AM
Mr.Hollow's Avatar
It's been a while but I believe there is a fuse or something you can pull. Try searching "HID" "fuse" "DTRL" in the search bar. But make sure you click under the "web & images tab" for some reason the regular search function doesn't work very well.
Old Jan 25, 2016 | 10:37 AM
Fit Charlie's Avatar
It's fuse #15, "DAY LIGHT."
In the two long rows of fuses it's the second row in, fifth from the bottom. First thing I did to the car.
The fuse diagram is on the outboard side panel of the driver's footwell. Sticking your phone in there to get a pic is the best way to get a look at it.
Old Jan 25, 2016 | 06:46 PM
DrewE's Avatar
By the way, on your car the DRLs can't operate at the same time as the headlights because they are the headlights operating at reduced power.
Pulling the fuse does disable the system. I don't really understand why anybody would particularly want to not have DRLs, as having one's car visible to others on the road seems like a good thing to me, but perhaps that's not really any of my business.
Old Jan 26, 2016 | 09:25 AM
The same bulbs, and a switch to operate them right next to my hand when needed. What is one to do?
If being seen by others is your concern, note that the side and rear marker lights don't work unless you hit that switch. DRLs are only seen by people in front of you. And facing you. Hopefully you see them and aren't driving a stealth car- and if your car is silver, hopefully you have your lights on in times of reduced visibility like the rest of us.
DRLs are stupidity that offends me. But if you're into them, that's none of my business.
Old Jan 27, 2016 | 02:15 PM
I was thinking of getting these:
I have a jdm ge8 rs.
Has anyone here installed these or anyone you may know of elsewhere?
Attached Thumbnails Day time running lights-80-fit_fogs_387c01058f7298a8d988336af45b68edafe14ed0.jpg
Old Jan 27, 2016 | 06:36 PM
Codger01's Avatar
Disabling the DRL's is one of the first "modifications" that I did. Those, along with instrument panels that are always lit have caused me to see more people driving at night with just the DRL's on. As you noted, no tail or side lights are on with the DRL's.
Maybe I just don't like having a "nanny" controlling things for me....
NightScreams
Feb 19, 2017 09:45 PM
quentinbeware
13
May 28, 2015 11:58 PM
j5ive
Canada Fit Forums & Clubs
18
Sep 16, 2014 01:52 PM
Orlandoech.com
Jul 2, 2010 01:35 PM
Marsbars
Sep 25, 2009 06:47 PM
