hissing in engine compartment by belt area
Old Feb 24, 2016 | 05:30 PM
Santiad's Avatar
So I popped the hood after driving to check the engine bay and heard a low hissing sound down by the serp belt area. No leaks but the leak worries me as I could be the water pump or AC compressor, both PITA jobs for me to do as I no longer have access to a full garage anymore.
does anyone have more info to determine if this is normal or whether I need to shelf any future mods and purchase a new water pump or ac compressor instead?
Thanks!
Old Feb 24, 2016 | 08:30 PM
ezone's Avatar
Normal.
Any time the AC compressor has been operating (with AC on, auto function, or defrost), it will be normal to hear hissing after you shut the engine off, as pressures inside the AC system slowly equalize.
Old Feb 24, 2016 | 08:33 PM
Santiad's Avatar
Thanks
I appreciate your input, thanks!
Old Feb 24, 2016 | 08:48 PM
ezone's Avatar
The AC noises can go on for a good 10 minutes or more after you shut the car off.
Note: If you smell hot antifreeze (sickeningly sweet smell) that would be a problem that needs pursued further.
The typical AC noises will never cause a smell.
biz4bucks
May 16, 2019 07:36 AM
Freemananana
Aug 7, 2015 09:02 AM
reako
Aug 11, 2010 09:38 PM
mega56
Apr 12, 2009 11:22 PM
docjim2
Sep 25, 2006 10:35 AM
