Manual 2nd -> 3rd gear question
Old Mar 23, 2016 | 09:18 AM
Jeema's Avatar
Hey guys,
My 2012 Fit's got about 53k miles now, manual transmission and I have a question about the shifting once again.
Anyway so I've been paying very close attention to my shifting recently (probably paying too much attention as I tend to be kind of ocd about cars), and I've noticed that 2nd to 3rd gear sometimes seems a bit more 'mechanical' feeling than other shifts. Don't know how else to put it.
I already had the transmission fluid changed, still seems to be about the same - maybe a little bit better, I don't know. I guess I've always felt the car has a very mechanical-feeling shifter in general, but it seems like that's the gear change I always notice. Maybe it's just the nature of the car? ...or should I be worried? I haven't driven any other Fits so I don't have any basis to compare. Which is why I'm here asking you guys!
Thanks,
Ben
Old Mar 23, 2016 | 11:01 AM
Fit Charlie's Avatar
I don't think so, but I can't say for sure. I'll try to pay attention to it on the way home tonight.
Old Mar 24, 2016 | 02:17 PM
dwtaylorpdx's Avatar
Your transmission gears are in clusters, IE pairs share some parts.
1-2 is the primary cluster, 3-4 is the secondary cluster and 5 is either paired with reverse or on its own. (90% of manual transmissions are set up this way. )
So your moving a different set of parts on the 1-2 shift than the 2-3 shift, its very possible you can feel the difference. Its not like you'd pull it apart yet unless its actually a function issue. Many transmissions have a tighter or looser cluster set for 1 pair, normal tolerances would cause it.
Old Mar 24, 2016 | 05:31 PM
That makes sense. It feels mechanical, but not in a bad way.
Old Mar 24, 2016 | 05:34 PM
Jeema's Avatar
Yea that makes sense.
I thought it might also have to do with the way I shift. I tend to just 'go diagonal' when going when going from 2nd to 3rd, but I read somewhere else that that's bad form and you're supposed to kind of do it more like a 2 step process when going from 2nd to 3rd. Maybe I've just been driving stick shifts like an idiot all these years...
Old Mar 24, 2016 | 06:23 PM
all you have to do is drive a Yuke for a week, you'll be a master for life..
Old Mar 25, 2016 | 07:46 AM
Originally Posted by Jeema
I tend to just 'go diagonal' when going when going from 2nd to 3rd, but I read somewhere else that that's bad form...
Do it as a two step process all at once. As your arm is driving it forward diagonally, use your wrist to move it to the right. If you can use two pedals at the same time, adding a flick of the wrist shouldn't be that hard.
m_x
72
Nov 16, 2018 04:10 PM
Ryfle
Feb 24, 2017 05:39 AM
Jeema
Jun 22, 2015 06:27 PM
Romulus
Sep 21, 2010 08:00 PM
blackdot_fit
Jul 14, 2008 05:36 PM
