P0107 Map Sensor
Old Jun 1, 2016 | 08:05 PM
De36's Avatar
P0107 Map Sensor
45k miles on my GE8. I read that it could be the connector to the sensor. It is very intermittent, and goes into fail safe mode during driving. I am not able to go over 3,000 rpms.
Has anyone ran into this code?
EDIT:
I purchased the MAP sensor for $60 and installed it. It did not fix my P0107 Map Sensor Low Input Voltage.
I put dielectric grease into the harness-side of the MAP connector. If it was a connector issue putting dielectric grease would exacerbate the problem. Sure enough it did. I ordered pigtail harness from Ebay for $15. Will install it this week and update.
______
Old Jun 2, 2016 | 03:13 PM
Boostedtaco's Avatar
That code is the bane of my existence. But my car is modified. It could be the sensor or the connector. Try cleaning the terminals for the sensor, i think there is some spray for that.
Good Ruck!
Old Jun 2, 2016 | 03:48 PM
De36's Avatar
Here's a thread for the GD that I was referring to, it's not very detailed and is for the Kraft works super charger:
https://www.fitfreak.net/forums/fit-...ap-sensor.html
Old Jun 2, 2016 | 04:18 PM
Ah gotcha. I have that issue in around the 3000-4000 rpm range part throttle. I can reproduce it at will unfortunately. I haven't dug too much into it yet.
Old Jun 2, 2016 | 04:19 PM
De36's Avatar
I still have a feeling it could be the connector at the sensor.
Have you replaced the MAP sensor yet?
Old Jun 2, 2016 | 06:31 PM
dwtaylorpdx's Avatar
if you can find the voltage range for the factory sensor, the GM sensors are rock solid, and easy to adapt. if the signals are the same.
The GM/Delphi sensors comes in NA, and about 4 ranges for Forced induction.
sLiVeRwOrM
Mar 21, 2023 06:48 AM
fitowner10
Mar 9, 2019 09:02 PM
Hirvi
Nov 25, 2011 11:11 PM
Koi
May 8, 2011 08:24 AM
gthumb23
Oct 18, 2006 01:05 AM
