Plastic Hood Underside Tray?
Old Aug 15, 2016 | 03:48 PM
ibeckman671's Avatar
I've never actually noticed this piece under my car hood, but apparently the dealer sucks and didn't fix it and left it like this: IMGUR
Is this hood part necessary? Does anyone know the replacement grommets for it?
From what I've gathered, it would appear that yes, it guides air to the box, but whether or not that's critical is not clear. Bernardi doesn't appear to carry the hood part anyway
Ideas?
Attached Thumbnails Plastic Hood Underside Tray?-80-4ibsbb5_36ab5ef349edbfe994b0e288f531f6e41f0fc9e6.jpg   Plastic Hood Underside Tray?-80-rsi45mo_88305f177c04763c44ee4cccfb10c330cab7c224.jpg
Old Aug 15, 2016 | 10:50 PM
Andrei_ierdnA's Avatar
Check Amazon or Ebay for Honda plastic clips/pins/bolts/screws, whatever they are called. Should find them in packs of 10, 20 or more.
That duct helps the engine get a much better supply of air, especially when it really needs it the most: at high RPM's and when VTEC kicks in
But if you drive like a grandma/grandpa until you get it fixed it will be fine. Just don't expect your little 1.5L engine to perform as well as usual. You can remove the duct entirely and your car will be fine.
However if you're like most people and drive an automatic, use the AC a lot, need to accelerate fast to keep up with traffic and will sometimes carry a full car, then you should definitely get the duct fixed up.
Old Aug 16, 2016 | 04:48 AM
Black3sr's Avatar
Go back to dealer and have them stick in the few clips they left off. Or any parts store will carry them. Just take one in to make sure get the same size.
Old Sep 10, 2016 | 05:32 PM
Yossarian147's Avatar
In the service manual this is the "cooling duct" on p. 20-153. Took me a little while to find so maybe this will help others. Clip part number is 91501S04003.
Old Sep 12, 2016 | 03:45 PM
Punisher11's Avatar
just a FYI, these clips are smaller than the regular body clips
Old Dec 16, 2019 | 02:39 AM
MyEggy's Avatar
This is EXACTLY what it looks like under my hood; it is even hanging by the same one pin!!!
I went to the parts store and was sold some rubber pins for the bumper that look exactly the same and while I can push it through the rubber hole it won't fit the hole in the metal hood.
Guess I'm going to have to go to a dreaded dealer. =((((
Thanks
Old Dec 17, 2019 | 06:33 AM
Red 05's Avatar
Thanks
I used generic plastic "Christmas tree" fasteners with mine and it's stayed in for a few years now. They're maybe 2 bucks for a pack of four, and can get them anywhere, even Lowe's and home Depot.
Old Dec 17, 2019 | 02:27 PM
MyEggy's Avatar
That's a great idea! I was thinking I was going to probably have to come up with something on my own.....
Thank you!!
Old Apr 17, 2020 | 05:12 PM
Sungmin Joe Cho's Avatar
Mine Looked same but I have additional question.
Does that cause rattling noise when going in low speed in like parking lots?
It sounds as if one of the stud/bolt that holds my tire is loose so it makes clunking noise but it doesn't make that sound when I'm at about 30mph or higher
Old Apr 17, 2020 | 05:24 PM
Red 05's Avatar
Studs are pressed into the hub, those would not rattle. Probably should insure your lugs are tight.
Old Apr 17, 2020 | 10:26 PM
MyEggy's Avatar
Unhappy
I have noticed a little "drrrrr" sound usually when I am accelerating after being still, say at a red light, or from a lower speed. I'm thinking it has something to do with my transmission. A light came on some time back, my mechanic reset it and said if it came back on to bring it back but it hasn't. But that noise is worrisome.
Old Apr 18, 2020 | 11:00 AM
Black3sr's Avatar
Could be end links. They wear out first in front suspension. I had mine replaced last years.
Old Apr 18, 2020 | 01:46 PM
MyEggy's Avatar
Thank you! What is an end leak please?
Old Apr 19, 2020 | 05:11 AM
Black3sr's Avatar
End link/ or stabilizer link
Old Apr 19, 2020 | 01:27 PM
56chevydan's Avatar
You use the terms rattling and clunking in the question in your post. Yes this plastic duct can rattle with only one clip holding it on to the underside of the hood and the rest hanging down into the engine compartment. If the noise you're hearing is more of a clunk, I'd check for looseness in your drive axles. Reach up under the car on both sides and check each axle for looseness. Grab the axles in the middle and lift and twist the center of each axle and see if there's looseness or clunking in them. Each axle has cv joints in them at both ends that can wear out.
Old Apr 19, 2020 | 03:28 PM
MyEggy's Avatar
HI,
Thank you for the responses. It's not a rattle or a clunk and I just had the tires rotated and checked underneath. I'm pretty sure it's not the CV joints; been there, done that. =(( But it's time I get the Eggman back to the mechanic for a major checkup ....they haven't seen each other in a long time!
KNPSHIN
Dec 20, 2015 12:41 AM
Blackberry Goose
Dec 28, 2011 06:02 PM
FitnessJay
Dec 22, 2009 09:27 PM
mozarwasagenius
Dec 23, 2008 05:31 PM
hanzo
Sep 4, 2008 07:07 AM
