AC Button
Old Dec 4, 2016 | 11:58 AM
JamesE's Avatar
AC Button
OK... so I've been searching around for an AC button (the one on my fit (2009) no longer works), any idea what it is really called? I found a drawing 79605-TF0-003ZA - Genuine Honda Display Assy., Mode *NH167L* (GRAPHITE BLACK) Of course, the part is not listed, just the bulb. Also, is the pulley bearing on the AC separate from the compressor clutch? Thanks in advance .
Old Dec 4, 2016 | 12:43 PM
ezone's Avatar
In your link, part #21 is the AC switch.
The bearing is staked into the pulley. Honda sells the pulley with the outer clutch plate as a set.
The field coil is sold separately.
The above are available separately from the compressor through Honda.
Those may not be available through aftermarket this way, most want to sell you a complete compressor, usually of dubious quality.
Old Dec 4, 2016 | 12:48 PM
JamesE's Avatar
Thanks for the quick reply and info Ezone.
Old Dec 12, 2016 | 09:01 AM
spike55_bmw's Avatar
Not sure if this is a problem either but my recirculation slide switch would stop at midpoint. Upon folding the glovebox down to look at the cabin filter, I saw that mice had built a nest on top of the filter from the insulating foam on my firewall. That mound of stuff (other fibers, seeds, etc but mostly white plastic) was preventing the recirc flat from opening (prevent recirc).
Attached Thumbnails AC Button-80-2011_fit_mouse_nest_2015_06_10_6f7123896a3a9dd645e339adc0e5f5b860657fa4.jpg
Jeff8bass
Jun 7, 2021 04:20 PM
redludesh
Jul 22, 2018 02:20 PM
billtmore
Jul 20, 2017 10:30 AM
laszlosujj
Jun 7, 2017 08:30 AM
FELIXY69
Jun 9, 2010 03:49 PM
