How to power LED DRL? What is ACC?
Old May 3, 2017 | 10:14 PM
justalilbit's Avatar
Hey guys, I'm doing a projector retrofit with Morimoto D2S 4.0 on my '09 Fit Sport. Here in Canada, Daytime Running Lights are mandatory so I bought some Morimoto LED rings. (Since the car would normally send low voltage to the high beam for DRL, I'll be removing the fuse as I've read this is the best solution to prevent wearing out the Xenon)
What's the best way to tap power to have the LED rings always on when the car is on, and off when the car is off? It needs 12V for full power. I've searched a lot but can't find a thread that says specifically what and where to find it. I usually read something about an accessory wire (ACC?) but not much more than the name.
Old May 3, 2017 | 10:25 PM
xxryu139xx's Avatar
get a tap a circuit and plug it into the fuse box under the dash board. i believe its fuse#34. someone else can confirm that.
Old May 5, 2017 | 01:03 PM
My owner's manual says #34 is low beam headlight. Is "ACC Socket" the one I want? It's the 20a fuse on #13
Old May 5, 2017 | 01:58 PM
xxryu139xx's Avatar
i believe i used #31
Michael Raymond
Dec 13, 2017 09:07 AM
esnave09
Nov 16, 2015 11:29 PM
Xtina
Oct 14, 2015 10:59 PM
SilverEX15
Apr 5, 2015 09:20 PM
B-Fit
Jul 19, 2008 11:02 AM
