blown plug - need new motor
Old Dec 30, 2019 | 08:53 PM
spike55_bmw's Avatar
Again, I'm curious why everyone wants to change coil packs when they are still working. Easy to change later it here's a code.
Old Dec 31, 2019 | 03:14 AM
Goobers's Avatar
"Everyone?"
When I changed my plugs at 134k, it was already long after the maintenance minder code for it came and went.
Unless you're talking about waiting for a DTC to pop... now, that would be silly.
Old Dec 31, 2019 | 06:41 AM
To me, a coil pack can easily / cheaply be gotten and be installed in less than 60 mins when changing all 4. I'm just skeptical about a display telling me what to do that is simply based on miles driven not matter how easy / hard / rain / desert / etc. I'm more willing to wait for the code / engine missing (1 cyl at a time - what are the chances multiple coil packs fail all at once and leave you sitting?).
That said, I'll get new tires (deep tread) prior to winter (Pennsylvania) even though my tires would be good / pass the state's annual safety inspections for another 10,000 miles in Florida / Texas. I just approach this differently. No right or wrong implied by me.
Old Dec 31, 2019 | 08:47 AM
Red 05's Avatar
So much of the car has to come out/off to be able to replace coils and plugs that I seriously doubt it's a 60 minute job. And the point of automotive maintenance is to not wait until failure to fix a wear item. I'd rather perform preventive maintenance on my time when it's convenient for me.
Old Dec 31, 2019 | 09:30 AM
I can guarantee that I can reach in on the passenger side with my left hand / arm with a 10mm socket on wrench for the coil pack bolts and replace each coil pack in less than 60 mins. If you're not fussy about torque specs, changing the spark plugs at the same time doesn't add much more time.
I agree it would take hours, if you are going to remove the windshield wipers, the plastic cowling, the full airbox, so you can access the rear of the engine and use a torque wrench on each plug, and them put it all back together. I'm done with that process, tried it and the plugs worked loose again anyway. I did the 'left-arm reach in' and put blue threadlocker on each plug and it has held up for 30,000+ miles. I guess I'm one of the luck ones since that process has worked so well for me.
NewEnglandD
Jul 16, 2021 02:37 AM
fitjoe
Mar 8, 2015 04:41 AM
Roger_PTY
Aug 25, 2012 12:49 PM
williamb
May 25, 2012 12:33 PM
Frank Boettcher
Jul 5, 2005 01:05 PM
