Radio code for ‘09 Fit
Old Dec 29, 2019 | 10:38 AM
SPickles828's Avatar
Hello,
I got a new battery and need to enter the radio code. I retrieved the serial number and got the 5 digit code but it has two 9’s in it. not sure how this can work because I only have buttons 1-6. And yes i’m positive it’s the code, not the serial number.
Old Dec 29, 2019 | 02:34 PM
Red 05's Avatar
Originally Posted by SPickles828
Hello,
There should be a sticker on the inside of the glovebox with the code on it. If you don't have the navigation radio you should only have the numbers 1-6 as your code.
Any Honda dealer will tell you what your code is if you bring it in.
EDIT:. there is a tool online for determining your radio code. It requires your VIN and radio serial number.
Old Dec 29, 2019 | 03:54 PM
Yes, I used the online tool for getting the code using my VIN and radio serial number. The code I received is 5 digits but had two 9’s. I have no sticker in the glove box or anywhere else on the vehicle nor did the vehicle come with a manual. I also do not have
a navigation radio.
Old Dec 29, 2019 | 06:01 PM
Red 05's Avatar
a navigation radio.
Then you have me in a bind. There isn't a reference to anything more than 6 digits in the factory service manual. Might be time to talk to a Honda dealer.
Old Dec 29, 2019 | 09:54 PM
howarejew's Avatar
I'll look it up on iN. PM me your serial
Old Dec 30, 2019 | 04:36 AM
n9cv's Avatar
When I needed a code for a 2009 about 7 years ago I called the 1-800 for Honda listed in the Owners manual and they not only gave me the code but stayed on the phone until I got it entered correctly and go tthe radio working again.
Old Dec 30, 2019 | 05:32 AM
steve37's Avatar
Just to make sure that you are looking in the right place....my sticker is on the outside of the glove box bin. Need to open it and look on the left side of it near the hinge.
Old Dec 31, 2019 | 10:04 PM
SiXiam's Avatar
My code is 65543 which was in with all the manuals. Not that it helps you, but at least it shows nothing above a 6.
john21031
Feb 23, 2020 06:19 PM
nigoleta
Jan 26, 2018 01:41 PM
Sheppard
Sep 30, 2017 11:21 AM
MiamiJazz
Mar 1, 2013 02:00 AM
mahout
Jun 4, 2011 08:17 AM
