Maintenance on "Maintenance Free Battery"
Old Mar 10, 2018 | 04:32 PM
Mister Coffee's Avatar
Had a few rough starts recently, so I thought I would check the battery. The Indicator window read "Distilled Water." Okay, fine. But as I went add the water, I noticed that the screws above each cell were almost sealed on in plastic. Okay, also fine. I got out a knife and started to hack away at the plastic when it occurred to me that I could unscrew the Indicator window and add water through there. So, that's what I did.
Did I do this correctly?
Thanks.
Note: Original OEM battery on a '13 Fit with 48k-ish mi.
Old Mar 10, 2018 | 05:24 PM
spike55_bmw's Avatar
I have more experience with lead-acid motorcycle batteries and always filled the individual cells as close as I could to equal. The fill line was always lower than the partition / baffle between the cells (6). So, your method would add distilled water at one point and then you would have to distribute it between the rest. Did you have the battery out of the car so you could rock it back and forth? Hey, everything is probably as good as it is going to get. I'm no expert. Car still starts, right? My intuition says that if the levels are too high, there might be more "cooking over" that occurs when in the charging phase and that means acid getting on stuff, but I have no way of knowing if that actually happens. Report back. Thanks
Old Mar 10, 2018 | 08:51 PM
Today, I put about 15 mi. on it. About four stops-and-starts. It runs, but now the Indicator is dead. It doesn't have a red dot at the center, nor a blue circle or a red circle around. Will check it again tomorrow.
Who's got the link for the battery retail store in L.A.? What's the going rate on a new battery from the dealer?
Old Mar 11, 2018 | 06:44 AM
Not sure what a dealer would charge but mine was +/- $90 after turning in the old battery. I still don't confident starts in the winter (PA) with the 151R battery but it never left me sit ('11 Sport AT ~70K miles).
Old Mar 11, 2018 | 12:53 PM
I'll have to find the thread that discussed battery replacement and the 51R. I don't feel like fussing with a larger size battery, but the thread mentioned a battery retail store (on Sepulveda Blvd in the SFV?) that might have an OEM.
Old Mar 11, 2018 | 02:52 PM
Gonna see if I can get me one of these bad boys. The store is open today.
https://www.batteriesplus.com/batter...finder-box-top
Old Mar 11, 2018 | 03:37 PM
xxryu139xx's Avatar
get an AGM battery. forget lead acid.
Old Mar 12, 2018 | 10:10 AM
Andrei_ierdnA's Avatar
LOL - do you care to enlighten us what type of battery is an AGM, if not lead acid as well?
Old Mar 13, 2018 | 08:11 PM
xxryu139xx's Avatar
Old Mar 14, 2018 | 12:47 PM
dll932's Avatar
My last one was an OEM...with removable caps the dealer said was sealed.
Old Mar 14, 2018 | 01:13 PM
LOL - Google is indeed my friend, one of the smarter & more reliable ones.
I was just being a lil' prick taking a jab at your mistake when you said: "get an AGM battery. forget lead acid."
http://batteryuniversity.com/learn/a..._glass_mat_agm
Absorbent Glass Mat (AGM)
Learn what differentiate AGM from other lead acid battery types
AGM technology became popular in the early 1980s as a sealed lead acid battery for military aircraft, vehicles and UPS to reduce weight and improve reliability. The sulfuric acid is absorbed by a very fine fiberglass mat, making the battery spill-proof...
Old Mar 15, 2018 | 06:15 PM
splat matt's Avatar
When I replaced my fit battery last year I had a difficult time finding one that would fit properly as well as have the correct terminals located on the right side. In the end, I went to the dealership and used a Costco coupon after tax was around $85.
ranplett
Jun 10, 2019 10:50 PM
exl500
Mar 31, 2018 12:02 PM
Marrk
Feb 2, 2013 01:43 AM
Triskelion
Mar 23, 2012 05:31 PM
D50boy
Oct 4, 2011 03:18 PM
