OEM vs aftermarket control arm and tie rod
Old Oct 15, 2018 | 02:14 PM
Gobstopp's Avatar
I have a 09 fit with 133k miles. I’ve replaces the front hubs and bearings, and I’m about to replace the rears this weekend. I plan on ordering new oem axles, as there is some play, and some grease leaking from the boots. While I was at it, I figure I should replace the control arms and tie rod, as the boots and bushings are worn and could be replaces.
looking into it, i was hoping to upgrade my control arms. I don’t see many options, and I’m unsure about off brands. Nothing is marketed as above oem quality, so is oem my best option for control arms and tie rods?
Old Oct 15, 2018 | 02:28 PM
evilchargerfan's Avatar
how about just replacing the bushings for the control arms?
https://powerflexusa.com/fit2014.aspx
as for tie rods, I believe moog makes some decent quality stuff (I have their "problem solver" end links). if the price gap isnt too bad, stick with oem
Old Oct 15, 2018 | 06:36 PM
Gobstopp's Avatar
Well, I don’t have a press. So I would have to take them to a shop and press them in/out. I figure by the time I buy those bushings, plus the new boot parts, plus paying to have them pressed in, I might as well just buy a new arm with everything pre installed. Rockpprt had a kit from moog, comes with two complete“problem solver” tie rods, inner and outer pieces, plus two control arms with new bushings and boot pre installed, all for $186. I wasn’t sure about quality, as I’ve never heard of moog, and that deal seems almost too good to be true
phoenity
Jan 23, 2019 04:14 PM
Gobstopp
Oct 13, 2018 03:24 PM
Garagewerks
Jun 5, 2017 06:38 AM
super_fit
Aug 19, 2016 06:31 PM
Dave Wick
Oct 2, 2005 12:33 AM
