What temp will High Temp Warning illuminate?
Old Dec 6, 2018 | 06:13 PM
Parafortuna's Avatar
Recently replaced a radiator on a 2010 base model using a salvaged component and a modified connector into the ECT sensor. If/when this connection doesn’t work, how long until and at what temp will the High Temp Warning light illuminate? Not having a temp guage on the instrument panel, by what other means might I determine if the system is/not working? I’m waiting for a correct connector, btw.
Old Dec 7, 2018 | 02:20 AM
56chevydan's Avatar
I put a digital temperature gauge in my 2013 sport. It's mounted on the lower dash just above the console. I installed it for under $40.00. Best thing I think I've done on my car for peace of mind. The components can be purchased on Ebay.
My car runs between 174-200 degrees fahrenheit and is affected by the outside ambient temperature and whether the car is moving and has air running through the condensor cooling it. The radiator temp sensor will turn the regular electric fan on when the coolant temp reaches the high 190's. If you're running the a/c, the a/c fan will stay on and help keep the engine cool. The regular fan will go on and off depending on coolant temperature.
To address your basic question of how to know if the system is working. You actually won't know for sure without a temp gauge. With a salvaged radiator and a questionable plug-in connector you can't be sure of it working properly at all, or if a signal will get to the overheated symbol on the dash when it does overheat. In my opinion, all you can really do is listen for your fans going on and off.and make sure the radiator and overflow tank have coolant in them, and hope for the best.
Basically Honda cheaped out on these cars and omitted the temp gauge that was on all Hondas for many years. Now, without installing a temp gauge on these cars, you're basically waiting for the dash temp gauge to come on if there's a problem, to let you know your car is already overheated.....
Old Dec 10, 2018 | 01:33 PM
Andrei_ierdnA's Avatar
You could also get an OBD II port gauge reader for maximum simplicity:
* ScanGauge II (I own one and very happy with it. It's the most expensive option, but well worth the extra cost. Mine is 4 years old and going strong).
* UltraGauge
* one of dozens of Bluetooth models that connect to your phone
Old Dec 10, 2018 | 06:22 PM
Developments
I’ll definitely look into those-
in the mean time...
Reservoir level is down, indicating to me that coolant IS flowing/being used...? Connector still in place, haven’t noticed any symptoms of overheating. Interestingly (I hope), it has been pretty chilly the past few mornings and my Cold Temp Indicator has stayed on a significantly longer time than it normally would in moderate weather; is this possibly a reliable sign that the ECT sensor IS, in fact, connected?
Appreciate yall’s help and experience 👍
Old Dec 11, 2018 | 12:44 AM
justus's Avatar
Yeah,,, OBD II
ELM chip.....
by Panlong...... they are like ten or twenty bucks and grab and App......
Trying to think which one I have... he app was like 5 bucks.....
I grabbed one called Torque.......
Old Dec 11, 2018 | 10:08 AM
Which fan is which?
When idling the passenger side fan will spontaneously turn on and then off after about ten seconds. I thought this was the condenser fan, not the radiator fan?? Drivers side has yet to activate, to my knowledge...
Old Dec 11, 2018 | 01:26 PM
56chevydan's Avatar
The a/c fan comes on when you turn the a/c on. Turn the a/c off and that fan goes off and stays off. The other fan is thermally controlled by a temperature sensor. When the coolant reaches the mid to upper 190 degree range fahrenheit,, the temp sensor turns the primary fan on and off to keep the coolant cooled down to a temperature under the temperature the sensor is set to come on at.
To confirm which fan is which, turn your a/c on before the engine gets hot and the primary fan comes on. The a/c fan should come on and stay on as long as you have the a/c on. This is probably the fan you say hasn't come on yet as far as you know.
Consider putting some kind of gauge in your car. whether it's a scan gauge or a regular gauge and you won't be guessing whether the system is working or not.
SilverEX15
Sep 22, 2014 10:45 AM
wzard999
Nov 17, 2013 08:58 PM
07fitsport
21
Nov 7, 2009 06:58 AM
NotraFit
Dec 29, 2008 02:55 AM
mmdir2002@yahoo.co.uk
Jun 27, 2005 08:22 AM
