AC diagnosis needed
Old Jan 10, 2019 | 09:12 PM
Dallasdave's Avatar
AC diagnosis needed
Hello all! I have an 08 Fit and the compressor is not engaging and the condenser fan also does not come on. I put gauges on the high and low. Low was 65 and high was about 70. Tested the relays in the box by the battery and they both clicked when I jumped power to them. I pulled the pressure switch on the high line and tried jumping it to no avail. Don't see one on the low line anywhere. I pulled the electrical plug to the compressor and was getting 4.5 volts with the key on whether or not the engine was running. Zero with the key off. Jumped from the battery to the plug going into the compressor and got Sparks and the wires got hot but no click on the clutch coil. That was with the engine off but I don't think that should matter. Am able to turn the compressor by hand and it feels like moderate resistance but turns well . I'm guessing the clutch coil is bad but the 4.5 volts confuses me. What say you?
Old Jan 11, 2019 | 09:21 AM
FitG8Guy's Avatar
I also would be leaning towards the clutch. I have an extra compressor actually if you're interested...off a 2010. Can match the numbers to see if it's the same.
Old Jan 11, 2019 | 09:35 AM
Dallasdave's Avatar
I I might do that yes. Did you know where the low pressure switch is? The only sensor IC with wires coming out of it connected to a pressure line is on the high pressure side
Old Jan 11, 2019 | 10:01 AM
FitG8Guy's Avatar
There is only one pressure switch...I'll see if I can find a wiring diagram
Old Jan 11, 2019 | 10:14 AM
FitG8Guy's Avatar
Old Jan 11, 2019 | 10:16 AM
Dallasdave's Avatar
Oh ok. Well I tried jumping it and it didn't affect anything. With it plugged in I got the 4.5 volts reading in the 2 outer wires of the 3 going to the compressor. As I now understand from stuff I read this morning, that is the go ahead signal from the pressure switch to the coil relay. I need to test again and see if the center wire of the 3 is hot with 12v. If it is then the coil or the coil relay is bad. If it isn't then it's electrical problems before it gets to the compressor. I'm also going to hot jump the relay by the battery and see if that activates the coil. I read that also this morning. I'm new to this if you can't tell. 😐😁😀
Old Jan 12, 2019 | 01:34 PM
Dallasdave's Avatar
Thanks for the wiring diagram. I pulled the connector on the power wire to the clutch coil and hooked up the battery to it and nothing happened. I'm certain the clutch coil is bad. I really triple checked it and used my multimeter to make absolutely sure I had power in the hot wire. The question now is, if, through puppy like exuberance and lack of fear, I ran a hot wire and a ground wire into the 2 wires that connect to the compressor near the rear, what would that do? The wires got hot immediately. Is that a low pressure switch built into the compressor? Is it worthwhile now to try and just change out the clutch coil or should I be safe and do the whole compressor under the assumption that I destroyed it? SMH .Learning
Old Jan 12, 2019 | 04:09 PM
FitG8Guy's Avatar
Whoa cowboy! Lol
Did the connector come from the compressor and have a Wht/Blu and Blu/Wht wires? The wiring diagram is your friend...there is a box around a thermal protector and a/c clutch in the diagram...those would be your compressor connectors. According to the diagram, there is a thermal protector in the compressor...if gets hot, shuts off. It’s only a switch. You shouldn’t apply voltage there, that’s why it got hot. You basically connected the positive directly to a negative without any fuse to blow and protect the wiring.
On A/C....9 out of 10 times it’s either a leak or compressor wore out and is no longer compressing enough to bring the high pressure up enough. Coils can fail also but electrical failure is pretty uncommon.
So you have 65 psi on the low side with car off/compressor not running, right? (low is always the larger sized lines, high pressure is small size lines)
Unplug the connector going to the clutch and put a volt meter on the 2 wires to measure voltage. Don’t apply any power to anything...that’s risking damage. Just measure voltage on the vehicle side of the connector and turn vehicle to run position and turn a/c on...let me know what happens. You may need a helper but only measure voltage of those 2 wires. You should see a change with a/c and turned off.
Old Jan 12, 2019 | 06:08 PM
mk2mike's Avatar
Sounds like you already got it covered.
on pin 3 (white/blue) it should be 5v w/ AC on
Coil resistance to ground should be 3.15 to 3.45 ohms at 68 degrees F, if it's extremely high or open, you have a bad coil or thermal protector
Old Jan 12, 2019 | 07:39 PM
Dallasdave's Avatar
Whoa cowboy! Lol
Well I already applied power directly to the clutch coil. Nothing happened. No click over. Nothing. I also jumped the power thrpugh the relay and also nothing. Ive seen several videos where that is considered valid tests. I checked the power input to the relay and it was 13v. I did the same thing on the horn relay and the horn honked. Why wouldn't the clutch coil engage when power is applied if it's working?
Gejiwhat
Jun 15, 2024 07:39 AM
dwtaylorpdx
Jul 26, 2017 11:03 PM
gahris
May 14, 2017 04:51 PM
Strastech13
Apr 22, 2017 07:22 PM
fitit2010
Jul 9, 2013 03:08 PM
