Rattle at high RMP
Old Jan 12, 2019 | 07:17 AM
Temmett's Avatar
Rattle at high RPM
I have been reading many posts on this site and a lot of people were saying it was the header heat shield. However, I found my problem to be the passenger side Axle heat shield. Now I am not saying it couldn’t be a header heat shield. In my case it was the axle heat shield.
I have a rattle the doesn’t exist when cruising around town but at highways speeds the rattle would start while accelerating on the passenger side floor board.
There is an issue with the steel wool like washers that are used. They wear away and the bracket is free to left giggle and rattle.
Hope this helps!
here is a Honda diagram and it’s part #19 I am referring to.
https://estore.honda.com/honda/parts...b=B++2101&dl=#
Old Jan 13, 2019 | 02:22 PM
Fiting's Avatar
Thanks Temmett. We have rattling on 2011 Fit Sport but sometimes on acceleration around town. Dealer and independent shop weren't able to fix so we will check this!
Old Jan 13, 2019 | 03:38 PM
Temmett's Avatar
Let us know if that was it
Old Jan 13, 2019 | 06:08 PM
macbuddy's Avatar
Rattle in my Fit turned out to be a bad Catalytic converter.
Old Jan 13, 2019 | 06:30 PM
Fiting's Avatar
Thanks macbuddy. How many miles did your OEM cat last?
Old Jan 13, 2019 | 06:42 PM
macbuddy's Avatar
Just so happened that I wrote this down.
I first triggered a P0420 when my OEM Cat started having problems at 337,064 miles.
(FYI, I have a 2007 5AT).
Old Jan 13, 2019 | 06:46 PM
Fiting's Avatar
Thanks macbuddy. New Fit is at 64K so hopefully that is not our issue!
Old Jan 14, 2019 | 07:20 AM
spike55_bmw's Avatar
Mine started to rattle and then fell off at 73,000+ miles. Just don't park in tall dry grass - no protection = fire hazard.
Old Jan 14, 2019 | 09:30 AM
Fiting's Avatar
What heat shield is that? Where is it located? Thanks.
Old Jan 14, 2019 | 07:21 PM
Around catalytic converter.
Jared592
Feb 28, 2026 08:27 PM
fenixfire077
Mar 4, 2019 01:24 PM
captainhowdy
Aug 27, 2018 06:49 PM
Jared592
Jul 10, 2017 10:44 AM
im the fit
May 30, 2009 01:28 PM
