Where is the headlight relay?
Old Jan 24, 2019 | 07:47 AM
Will Andrews's Avatar
I have a 2009 Fit. Which relay is for headlights? The owner's manual is useless in this matter (and most) . I can't find a useful diagram anywhere.
Old Jan 24, 2019 | 10:12 AM
Connor MacInnis's Avatar
Do you mean fuse? If so, fuse 9 is a 20amp for the fog lights. Fuse 15 is 7.5amp daytime running lights. Fuses 32 and 34 are both 10amp passenger and driver side headlight low beams respectively.
Old Jan 24, 2019 | 10:28 AM
Thanks, but no. I mean relay. My low beams are noy working but the fuses are fine. I want to check relays but they're not labeled.
Old Jan 24, 2019 | 02:28 PM
56chevydan's Avatar
The '09-'12 factory repair manual shows a lighting relay in the under dash fuse panel on the driver's side of the car. As you face the fuse panel. the relay is in the upper row, in position four- fourth from the left. I do not see any mention of a relay just for the headlights. The manual shows the relays in sections 22-55 and 22-56.
For reference, I believe someone has downloaded a factory repair manual on this forum that is downloadable by forum members for their use.
metal
Nov 5, 2019 06:18 PM
eCity Fit
Oct 18, 2014 10:44 AM
alanchan
Jun 1, 2012 12:05 AM
mole177
Jun 16, 2009 01:44 AM
Fat Ping Cat
Jul 5, 2008 12:34 AM
