GE8 i-vtec Light?
Old Jan 13, 2010 | 12:50 PM
Troubler's Avatar
GE8 i-vtec Light?
Anyone know which colour, or pin number the vtec switch is on the ECU? Lots of info on here about GD vtec lights but couldn't find one for GE... I'll volunteer to do a DIY if someone can point out "the wire". (Honda employees, where are you?)
Old Jan 13, 2010 | 02:09 PM
wpyeo's Avatar
source from a friend of mine....
You can DIY a light by running a wire with a 3mm/5mm LED with 470ohms resistor from the solenoid of rocker arm to detect the vtec signal.
When ECU send the 12V signal to solenoid, it will light up.
There only two wires connecting the solenoid.
Green+Yellow = Positive
Brown = Negative or ground.
Old Jan 13, 2010 | 06:36 PM
FITProject's Avatar
Vtec just kicked in yo!
Old Sep 15, 2011 | 08:17 PM
brEAd's Avatar
sorry for reviving an old thread but im really interested. anyone come up with a DIY yet?
Old Sep 15, 2011 | 08:47 PM
BlackPearlFIT's Avatar
^^^ Agreed, I'm also interested.
Old Sep 15, 2011 | 09:43 PM
DiamondStarMonsters's Avatar
It's spelled out for you in post #2.. How much more simple could he make that?
Old Sep 15, 2011 | 10:06 PM
brEAd's Avatar
alot more simple haha. and more detailed pictures perhaps
Old Sep 15, 2011 | 11:06 PM
555sexydrive's Avatar
I have mine connected directly to the ECU. I attached a drawing I made up in paint of the ECU pins and which 1 to use previously. Let me locate and reattach to this or just use the solenoid. For the ground, I just have it grounded to the chassis.
I have my LED mounted in a hole already present in the steering column, when I replaced the stock steering wheel the hole was exactly perfect for the LED I was using. VTEC kicks in at 5200rpms (J's reflash) and 5300rpms is stock activation, so if you don't see it light up, then you did something wrong.
Old Sep 16, 2011 | 01:55 AM
brEAd's Avatar
i almost understand the steps now, but if anyone can do a full diy i would really appreciate it
Old Sep 16, 2011 | 03:44 AM
Red 05's Avatar
That is a SICK set-up on your GE8 there dude, I envy you!
Old Sep 19, 2011 | 05:39 PM
Lyon[Nightroad]'s Avatar
You vampire tap the vtec solenoid its childs play.
Old Oct 5, 2011 | 04:10 PM
FitStir's Avatar
It would be nice to tap that pin with this gauge ---> LEDmod.com Color Changing Gauge Face [Shift Light] - YouTube
Vtec just kicked in....
Damn, I really want that mod for the gauge.
Old Oct 5, 2011 | 06:09 PM
MNfit's Avatar
what is the point of this light? I never understood the reasoning for it.
Old Oct 5, 2011 | 06:25 PM
FitStir's Avatar
It's supposed to let you know exactly when vtec engages, afaik nothing more nothing less. Ofcourse you could also do that by looking at the rpms provided you know at what rpms it engages. 555 posted em in the previous post.
I didn't really care for it, since I don't push my car that often, but after seeing that youtube mod for that Toyota gauge, I thought that would be a good idea to sync with vtec kicking in.
Old Oct 5, 2011 | 06:28 PM
MNfit's Avatar
I guess I kind of knew what the point of it was, just had hopped some one had a better answer then "just because" *shrug* To me it seems pretty pointless to wire up a light just so you know when VTEC kicks in YO!
Old Oct 7, 2011 | 05:09 PM
dridge11's Avatar
I'm glad you asked, I was wondering as well.
I'd rather hear it or feel it, which I hope would be the case. If neither of those happen, I certainly don't need a light that brags about it.
Old Oct 8, 2011 | 02:56 AM
This bears repeating...
Bayu Tuk Windriyo
Jan 9, 2021 10:06 AM
Lyon[Nightroad]
Jul 5, 2016 12:32 PM
lakia5524
Apr 21, 2014 09:59 AM
GrocerySnake
15
Nov 3, 2011 12:15 AM
Zangoose GD3 Blue
Sep 17, 2007 12:15 PM
