When Hazzard is ON, Lights Flickers
Old May 21, 2019 | 04:01 AM
loybu's Avatar
Hello Everyone!!
Im kinda new here, I just wanna consult my problem with my JAZZ 2013,
recently I installed aftermarket HORN and OBD for safety/autolock hazzard
the PROBLEM is:
When the KEY is ON, (car not started) Hazard will activate but the lights from my dashboards and stereo will flicker/flash also same with the HAZARD lights
Horn installed with Relay, just got the trigger from the stock horn line to trigger the relay directly connected to the battery
add:
If I will turn on the lights, the ficker will go away ( I suspect something in the dimmer? )
tried to remove the OBD acc, and turned the HAZZARD, the problem is still there...
Tried to replace Battery still the same
Tried removing the relay of the horn, still the same (but im sure its not related I just tried)
thanks and regards to everyone
dbcmaster
May 16, 2017 07:34 AM
TKZ12NO1
Feb 25, 2012 04:45 PM
torv
Aug 29, 2010 12:33 PM
secondspassed
Dec 7, 2009 04:05 AM
gummyrabbit
Nov 23, 2007 03:30 PM
