Honda Jazz leaking
Old Feb 15, 2010 | 11:05 AM
Cosybears's Avatar
Honda Jazz leaking
My 2005 Honda Jazz has developed a leak in the spare wheel well and under the off side rear passenger seat. We have water tested the car with a hose and cannot find where the leak is coming from. The rubber seal around the hatch back door does not appear to be damaged in any way. Can anyone suggest anything?
Old Feb 15, 2010 | 07:23 PM
Type 100's Avatar
Hmm, have you tried disassembling the interior trim panel around the rear off-side? I removed all the lower interior trim from the hatch area for fun once. Sadly I found some rust spots, which I had a body shop take care of for me.
That might help you locate the leak. Good luck!
Old Feb 15, 2010 | 08:08 PM
krakhed's Avatar
https://www.fitfreak.net/forums/fit-...into-boot.html
check that one out...should give you a starting point at least. there are some issues with leaks but honestly i think it varies and unfortunately i had a couple issues.
g'luck with fix man.
Old Feb 15, 2010 | 10:11 PM
Type 100's Avatar
Interesting, so it IS underneath the hatch area interior trim. Fortunately I haven't had any leaks of that sort so far...fingers crossed
Old Aug 13, 2010 | 11:53 PM
Jazz_Pinkz's Avatar
it happen to me as well.. but i think this was happened after i had an accident about 2 years ago..
it starts leaking.. so, i find a spot where the repairmen did not notice that the seal from the factory had been removed.. so i seal that spot, it works, but just now, i notice that it still leaking.. but not like the firts time.. i'm really curious where did it came from..
stevey117
Aug 8, 2023 03:09 PM
feenster
Aug 14, 2010 11:45 AM
90crxfreak
Jan 12, 2010 11:54 AM
rivierasun
Oct 11, 2006 12:12 AM
stradbally
May 18, 2006 05:13 AM
