My horn upgrade!
Old Feb 22, 2010 | 04:52 PM
ej96hatch's Avatar
My horn upgrade!
I guess this is the appropriate forum to post this in so... I had my horn setup from my civic before I had the fit! I mounted them to a bracket that I fab'd up rather quickly/simply! I made the bracket so it centered the horns almost perfectly behind the "H" emblem in the front grille so they can't really be seen! I didn't want to cut into my stock horn wire so I used a male connector and cut it down to size until it fit snuggly into the female connector! Other than that I just wired the two power and two grounds up and had the horn installed in about an hour! All wires were soldered! The horns are from a Porsche boxster and there is 1 hi horn and 1 low horn! I like it much better now!
VIDEO: http://yfrog.us/6ddscn0001z
PICS:
Old Feb 22, 2010 | 05:33 PM
beangrower's Avatar
nice. got a sound or video clip of it? Is it louder or jus a different tone?
Old Feb 22, 2010 | 07:54 PM
ej96hatch's Avatar
I will get a video tomorrow! I took one earlier with the car in the garage but it was not clear at all so I will have to pull the car in the driveway and try again!
Old Aug 14, 2010 | 04:14 PM
Bohemian's Avatar
Just did similar mod to my 2009 fit base. I got a pair of hi-low horns from Harbor Freight and just spliced into existing horn. With the meep and hi-low it is very loud and noticeable.
Old Aug 18, 2010 | 12:26 AM
shaka808's Avatar
I just bought a '10 Honda Accord horn and installed on my'10 Fit Sport. It literally took 15 minutes, thanks to the DIY thread on the '09 Fit. It's WAAAAY Louder than the Fit's horn.
Old Apr 26, 2011 | 11:13 AM
jdmgpw04's Avatar
my 2011 fit S is louder than my 2009 fit S. not sure if they upgraded my speakers and was going to do this mod but ended up swapping my entire car might be a better choice hahaha.
Old Apr 27, 2011 | 12:28 PM
ThEvil0nE's Avatar
love the prominent highs on those horns... good job OP!
I stil find the single accord horn weak... better than meep but still weak for me.
Old Jun 11, 2011 | 04:14 AM
schuey1010's Avatar
Just did this MOD today with some guidance from ej96hatch, and I could not be happier. I got the set of porsche horns from fleabay for $40 shipped which seemed fair. The hardest part of the whole project is making the wire connections to the small hair like wires of the porsche horns. EJ96 said he was able to solder the wires on, but I wasn't patient enough for that, and my skills (and eyes) would never allow me to get it good enough for my picky self. I don't know what the accord horn sounds like that others have done, but if it's at all like my 04 accord horn, it's still lacking.
They sound just as great as his sound clip and really turn heads and get you noticed. Total cost of everything was about $45 and ninety minutes of time. If you have questions, fell free to PM me and I will help you out if I can.
Old Jun 11, 2011 | 09:06 AM
ej96hatch's Avatar
Thanks....
Old Jun 11, 2011 | 09:08 AM
ej96hatch's Avatar
Good job, glad I could help!
Old Aug 22, 2012 | 08:42 PM
wanted to point out that if you have wires that came with aftermarket speakers, the narrower spade connector will fit right into the female horn harness connector. then, just e-tape the wire and connector to prevent water entry.
thanks again for the picts. i wired up my G35C's stock horn onto my '12 today.
and i left the lock arm (beep) horn in tact on the driver side.
SilverEX15
Jun 16, 2015 08:23 AM
The Assassin
Aug 22, 2010 09:52 PM
FLEALAMI
Jan 23, 2010 03:57 PM
CMegalodon
Mar 12, 2009 02:04 AM
duckbill
Jul 5, 2005 07:44 AM
