water temp gauge
Old Sep 20, 2011 | 09:01 PM
MOTOMATT's Avatar
Question water temp gauge
I have a electronic water temp gauge that I want to install. Where is going to be the best place to tap off the engine for the sending unit? Also, what thread would this fitting need to be, my sending unit is 1/8" NPT?
thanks for any help.
Old Sep 20, 2011 | 09:40 PM
Pruav's Avatar
This won't help you but, it is something you might want to consider. I bought the Ultra gauge. It gives you many options for differnet gauges. I use it mainly for water temp, battery voltage, and mph. It just plugs into the odm port.
UltraGauge Automotive Information Center and OBDII Scan Tool
Old Sep 21, 2011 | 07:08 AM
Krimson_Cardnal's Avatar
^^ditto that^^
I pondered coolant temp gauge as well and settled on the Ultra Gauge. It is quite a nice unit mounted in the front quarter window. You might want to check it out.
How you liking the UG Pruav?
Old Sep 21, 2011 | 02:52 PM
Pruav's Avatar
Originally Posted by Krimson_Cardnal
^^ditto that^^
I like it. The one thing i wished it would display that it doesn't is the oil pressure.
Old Sep 21, 2011 | 04:23 PM
MOTOMATT's Avatar
Thumbs up
^^ditto that^^
Thank you for replies,
Can you just have water temp, battery voltage showing?
I like how easy it is to install the Ultra gauge.
I wanted to use a guage I already had
Old Sep 21, 2011 | 04:44 PM
Pruav's Avatar
You can set it up anyway you want. It can show up to six read outs on the screen. i have mine set to display Mph, battery voltage, water temp, fuel %, engine load, and UG internal temp.
I understand wanting to use what you already have on hand. I can't help you with its installation. The whole reason I bought the Ultra gauge was so I wouldn't have to mess with tapping the coolant system and run wires for the gauge. With the Ultra gauge you just plug it in and suction it to the small side window and then tie up the loose wires.
Are you going to want any other gauges in the future?
You might try posting in the general forum for more response for installing your gauge.
Old Sep 21, 2011 | 05:38 PM
Bringing my UG thread to the surface, it keeps falling off the radar: https://www.fitfreak.net/forums/gene...on-thread.html
K_C_
Old Sep 21, 2011 | 06:12 PM
Carbuff2's Avatar
I have a ScanGaugeII, similar to the Ultragauge.
If you have a Garmin GPS, you can also use their EcoRouteHD dongle that plugs into the OBDII port. The GPS then allows you to view virtual gauges on it's screen.
There are OBDII Bluetooth dongles that will send the gauge info to your smartphone, as well. I think Torque is one.
Torque Pro (OBD2 & Car) | AppBrain Android Market
Old Sep 30, 2011 | 06:01 PM
Eurohb's Avatar
If your really really wanting to see the water temp reading, there is another option by adding a water temp adapter to the coolant line. I did this on my BMW, since older BMW's have horrible cooling system's. I got my 52mm Water Temp gauge from Pro Sport gauges and got this type of adapter from ebay.
1.10" Water temp Sensor Adaptor Sil Gauge Radiator Hose | eBay
Here is how my prosport gauges turn on
2011-08-17_12-49-22_868 video by eurohb - Photobucket
Old Sep 30, 2011 | 06:11 PM
No pics??? I thought the same way, then discovered the UG that plugs into the OBDII direct and reads the vehicle systems. Pretty trick and $70!! 50 readouts, will show 18 of any in three screens.
Old Oct 24, 2011 | 10:10 PM
CharlotteGE8Alex's Avatar
anyone try Jet V-Force Plus Power Control Module
Old Oct 25, 2011 | 12:55 PM
fitisbamf's Avatar
15$ at orielys, ull need an inline hose adapter (2nd pic)
Old Nov 15, 2011 | 09:16 PM
12vltfrk's Avatar
just ordered the ultra gauge!
Old Nov 16, 2011 | 08:48 AM
MOTOMATT's Avatar
Which hose did you tap into ?
Thank you
Old Nov 16, 2011 | 11:07 AM
fitisbamf's Avatar
Thank you
upper rad. hose. i want to see temps exiting the block before the rad cools it. u can put urs after the rad to make sure its doin its job but ur temps will be really low on the gauge. the stock temp signal for the fans is on the bottom of the rad, this makes the fans not turn on till the rad reaches the correct temp, but the engine will be significantly hotter. i plan to find a plug and relocate the fan switch.
Old Nov 16, 2011 | 12:53 PM
Wanderer.'s Avatar
Posting here because this interests me.
I hate not having a temp gauge and have been wanting to put one in. That adapter looks like an easy solution.
What reading is more important? Coolant temp going into the block or exiting? I would think exiting the block would be a more useful reading and I suppose that's why you decided to place the sensor there.
Old Nov 17, 2011 | 01:20 AM
Red Rockit's Avatar
Most stock temperature gauges are on the upper radiator hose where it goes into the intake.
Old Nov 17, 2011 | 11:18 AM
fitisbamf's Avatar
it doesnt go into the intake.... it leaves the block and goes to the radiator, then back to the block, over and over again. so i put it after the block before the rad, to see temp change inside the engine
Old Jul 28, 2012 | 09:04 PM
j's_fit's Avatar
[QUOTE=fitisbamf;1044993]15$ at orielys, ull need an inline hose adapter (2nd pic)
Do u mind me asking what size is ur hose adapter??
Thx
Old Jul 30, 2012 | 04:16 AM
fitisbamf's Avatar
[QUOTE=j's_fit;1119059]
Thx
lol the pic with the water adapeter says 30mm on it...
