GE8 cable bushings
Old May 6, 2012 | 03:43 PM
superfly5203's Avatar
GE8 cable bushings
Does anyone make bronze cable shifter bushings for the GE8? I have seen lots for GD, but none for the GE8. Or do the ones for the GD work with the GE8?
Thanks,
Old May 10, 2012 | 06:42 PM
so I take that as a no, there are no replacement bushings for the GE8?
Old May 10, 2012 | 06:45 PM
hayden's Avatar
Not sure. This subforum doesn't get as much activity, but I bet someone knows. I can take a picture of mine if you still have your stock airbox in, and need to take a look at the assembly. There's a chance they could be the same.
Old May 10, 2012 | 07:37 PM
Funkster's Avatar
Torque Solution (manufacturer of the ones I installed) says they are the same.
Old May 11, 2012 | 08:15 AM
Thanks for the info. I guess I will try the Torque Solution ones. I miss the feel of a rod linkage, the cables just feel so.... blah. It seems the bushings help give a more direct feel.
Thanks again.
Old May 11, 2012 | 11:01 AM
hayden's Avatar
Thanks again.
I'd hope for that, but the stock bushings were very hard and the whole thing seemed tight when I checked it. I'd like a heavier spring on the return mechanism though so it doesn't wiggle in neutral. That product is out there for the 8th gen civic people, but that is either in development, or had someone on here test the waters with but didn't gain traction.
Old Jan 31, 2013 | 11:30 AM
pocketrocket69's Avatar
looking into getting the TWM ones.
Any have any experience with those vs. the Torque Solution or Corsport?
bluesaint
Feb 6, 2017 09:20 PM
yovtecjustkickedin
Dec 31, 2016 09:59 PM
Committobefit08
Oct 7, 2015 12:23 AM
phuccer
Sep 23, 2010 05:49 PM
acchan
Nov 23, 2009 09:29 AM
