no battery indicator on my 09 fit sport
Old Jul 30, 2012 | 06:08 PM
haliwu's Avatar
I did a jump start this morning and was advised to change the battery. I checked the manual and then for the first time noticed that there is a battery incidicator as described. However, I did not see it on my battery. A picture of it is attached. The ridiculous thing is that the indicator instruction label is there but no indicator.
Is this normal? This is the original battery since I bought my 09 fit sport as new from dealer. I bought it in 1/09, so it already passed the warranty.
Old Jul 30, 2012 | 06:18 PM
micven55's Avatar
The indicator is under the cap, just unscrew it and look.
Old Jul 30, 2012 | 07:08 PM
haliwu's Avatar
thanks for the info. I thought it was under the cap, tried to unscrew it with a quarter, but it seems to be very tight. so I gave up as I did not know what it is for. Now I am going to try again.
Old Jul 30, 2012 | 09:42 PM
kodok3ribu's Avatar
while you're at it.... clean it?
Old Jul 30, 2012 | 11:48 PM
haliwu's Avatar
yes, I think i need to clean it, but my battery is over 3 years now, so I am considering if I should just get a new one. the battery got a jump start this morning (coz i forgot to turn off the map light overnight), and i was advised to change the battery. the battery running out and the jump start will shorten the battery life, right?
Old Jul 31, 2012 | 07:39 AM
malraux's Avatar
Running a battery low can damage it. But I would get it tested rather than automatically getting it changed. Auto parts stores will test batteries for free.
Old Jul 31, 2012 | 08:10 PM
jadr09fit's Avatar
Get it tested. Ours was dead after 3 years of regular use. It needed jumpstarting a few times before it completely died.
I replaced it with a Miata battery. There's a writeup around here somewhere. Saved $60 over an OEM-fitment battery.
Old Aug 1, 2012 | 04:39 PM
phenoyz's Avatar
where did you buy ur battery?
hydrocynus
13
Dec 25, 2021 05:42 PM
Spacecoast
15
Nov 26, 2015 02:05 AM
hogwylde
May 27, 2013 06:18 PM
oshow
Aug 12, 2010 03:19 PM
huskerfit
May 3, 2010 05:16 PM
