Rear passenger door windows not working?
Old May 15, 2013 | 03:15 PM
Codger01's Avatar
Won't go up or down from any of the switches. Fuses are OK. The lock out switch on the drivers door panel seems to work ok (locks out front pass window when engaged). Anyone have any ideas on where else to look to fix this?
Old May 15, 2013 | 07:25 PM
Dean's Avatar
How does the switch feel that you always use on the front drivers door?
I'd pull that one and visually check and clean it.
-Dean
Old May 15, 2013 | 09:17 PM
sr.sedan's Avatar
It seems that the master switch went out
Old May 15, 2013 | 10:14 PM
Codger01's Avatar
Yes, I am leaning towards it being a switch issue, possibly the one that locks the windows from the drivers door. Thed front windows work ok, the rears not at all.
Old Jun 1, 2013 | 09:13 PM
Codger01's Avatar
Wierd, un plugged and replugged in the switch last week, no change. Now I was backing out from my aunts house, went to open the pass side window and pushed the rear window switch instead- and it opened! Left rear still not working. Will have to try the replug thing again.
rocksnap
Jul 27, 2024 01:59 PM
fitowner10
Aug 22, 2016 09:53 AM
Santiad
Dec 8, 2015 08:48 AM
Body2Big
Jun 16, 2014 03:14 PM
Satchel
Jan 23, 2009 03:47 PM
