Headlight Internal Fogging (Help)
Old Jun 4, 2013 | 09:34 AM
Dark_templar's Avatar
Any gurus here knows how to clean the interior of the headlight lens as mine is fogging up pretty bad. Would appreciate if there is a way without dismantle the lens from the headlight as I do not have an oven or heat gun to heat up the adhesive to separate the lens from the headlight.
Old Jun 4, 2013 | 09:55 AM
DrewE's Avatar
By "fogging up", you mean water condensation, right? Assuming that's the case, I wouldn't really worry about it. It should dissipate reasonably quickly from the heat of the headlight bulbs when you have them on. It's not as though the headlight pods are sealed airtight; there's bound to be a little condensation in there under some conditions.
You can get some access from the back by taking the bulb holder piece out as though you were changing the bulb. I don't know that it would be sufficient for easy cleaning.
Old Jun 4, 2013 | 10:08 AM
Its not water condensation but more of a sticky or oily film of fog.
Bigaizsosexy
Jul 14, 2023 01:28 AM
GD3 GeGe~
May 29, 2020 02:17 PM
BigSpark
Mar 17, 2020 08:43 PM
smeister
31
Aug 3, 2014 04:18 PM
HONDAMATIC
Apr 14, 2010 11:39 PM
