2012 60k Mile recommendations?
Old Jul 5, 2015 | 01:20 PM
isis07734's Avatar
I know the coolant is one, but while it's in the shop- may as well do plugs, drain and refill MT fluid? Anything else?
Currently living in an apt, don't have a garage anymore- so oil changes are all ill do myself. Wife and I have only one car, she's out of town and i'm off for a few days- so i'd like to get some work done.
Thanks in advance
Old Jul 5, 2015 | 01:23 PM
I'd do intake and cabin air filters as well.
Check the brake pads, make sure they've still got some life left in them.
Old Jul 6, 2015 | 08:35 AM
isis07734's Avatar
Thanks Mike, ordered a cabin filter online. I could handle that one and the intake air filter, which I forgot about until recently. Luckily we mostly do country driving, almost had a panic attack about it.
Think I should get the valves checked?
Old Jul 6, 2015 | 07:24 PM
Waiz's Avatar
Avid FitFreak Poster
Brake fluid flush and rotor thickness check is what I would also suggest
Otherwise I think you got it covered with a trans fluid and coolant flush
Old Jul 6, 2015 | 09:47 PM
isis07734's Avatar
Thanks everyone
Old Jul 7, 2015 | 09:49 AM
Carbuff2's Avatar
I thought coolant was 110k miles or 5 years? Same with plugs.
Spend the money you saved on those items on a valve adjustment....
X2 on the MTF replacement and brake/clutch fluid flush.
BTW MT fluid replacement is no more difficult than an oil change.
Old Jul 7, 2015 | 10:10 AM
isis07734's Avatar
Hmm, good to know buff. Found this:
on MT fluid change, seems not too bad.. guess it would depend on how much they charge.
Old Jul 7, 2015 | 10:17 AM
Carbuff2's Avatar
If you have the work done at an independent shop, be sure to specify HONDA oem fluids BTW.
sarasube
Jul 4, 2018 11:08 PM
YA2_user_GD3
Jun 7, 2015 08:28 PM
Bogamire
Oct 2, 2014 09:05 PM
Bahamas
Feb 11, 2014 10:00 PM
tafkam
Mar 7, 2013 07:54 AM
