Transmission drain/fill crush washer sizes
Old Jan 13, 2017 | 02:00 AM
ian05s2k's Avatar
Hi all, I am getting ready to change out the manual transmission fluid on my 2010 Fit Sport and I have not been able to find either the part numbers or sizes of the crush washers for the vehicle. Does anyone know off hand either the size or part number for the fill bolt crush washer specifically on the 2010 Fit transmission? Any help would be greatly appreciated. I'm trying to avoid having to run to the parts store in the middle of the procedure to find the proper sized washer.
Old Jan 17, 2017 | 03:48 PM
spike55_bmw's Avatar
Might be easier to go to Honda dealer.
Old Jan 17, 2017 | 09:05 PM
ian05s2k's Avatar
Ha ha, it's been pretty easy asking on here so far as well. Plus considering the workers at the closest Honda dealer are limited in the competence area, this seemed like an easy start.
Old Jan 17, 2017 | 09:34 PM
xxryu139xx's Avatar
Old Jan 17, 2017 | 09:44 PM
So, $6 / 5 washers = $1.20 ea How many do you need to do the job? Maybe you can use the extra ones for oil changes.
Old Jan 17, 2017 | 10:34 PM
ian05s2k's Avatar
Looks like that link is for the automatic transmission. I did end up hearing from a local guy it is a 20mm for the fill bolt, and the normal one you use for oil changes on the drain bolt on the manual transmission cars. I'm hoping that's right so I can just use the ones I have a big bin of laying around for my S2000.
Old Jan 26, 2017 | 12:34 PM
sschoe2@gmail.com's Avatar
The oil change one is a different size.
Old Jan 28, 2017 | 02:20 AM
ian05s2k's Avatar
I was pretty sure that both the engine oil drain bolt and the transmission oil drain bolt were the same size. I will confirm and let everyone know once I get around to doing it.
Old Mar 2, 2018 | 04:56 AM
DaytonaFit's Avatar
Did you ever get around to finding out the size of the fill and drain on a m/t?
Old Mar 2, 2018 | 12:36 PM
Alco RS-1's Avatar
Gen2 ATF Drain Plug Washer - Honda 90471-PX4-000 (18mm ID x 26mm OD x 2mm Thick)
Old Jul 30, 2024 | 09:51 PM
jazzcat's Avatar
Thank you!
JerryHughes
May 16, 2019 12:12 AM
Pucci
Oct 1, 2015 08:26 PM
GeneralLee86
Mar 15, 2014 09:56 AM
MTLian
Honda Fit Dealer Reviews
Dec 18, 2012 12:58 AM
uniguar
Oct 7, 2012 10:08 PM
