Brake Booster delete
Old Jan 23, 2022 | 09:48 PM
Radi's Avatar
Has anyone deleted brake booster? Are there are any options other than custom fabrication?
It is a racing dedicated car. I know what booster does in case you are wondering.
Old Jan 25, 2022 | 11:04 AM
NWCH's Avatar
You do not need a brake booster when racing. Most are deleted. Boosters are mainly for street car use.
Old Jan 25, 2022 | 11:55 AM
AirborneRATT's Avatar
I think that the OP understands what it is and that it is not needed for racing. The question is how. I don't have that answer but am curious to know myself.
Old Jan 25, 2022 | 12:52 PM
Radi's Avatar
You can just plug vacuum line. I was just wondering if there is a part I can buy to replace booster with just a piece of pipe that matches booster dimensions. Alternative is custom fabrication of the part.
Old Jan 25, 2022 | 10:02 PM
Radi's Avatar
For now, I have made home made solution. Plugs on both ends of brake booster vacuum line. 1/2 inch tube and plugs from Lowe's. Still looking for solution to get rid of brake booster.
Old Jan 27, 2022 | 03:04 PM
GrE8_Fit's Avatar
Maybe plug off the booster and run a larger MC to compensate? Effectively making the booster a perfect spacer? I've always wondered, myself.
Old Jan 27, 2022 | 03:40 PM
Radi's Avatar
Will see. I do not need as hard brakes on gravel. I need to learn about sizing of MC.
Old Jan 30, 2022 | 04:26 PM
GrE8_Fit's Avatar
Here's a pretty interesting write-up from Honed:
https://honeddevelopments.com/booste...e-kit-testing/
Old Jan 31, 2022 | 10:39 AM
Radi's Avatar
Anyone wants to donate booster so that it can be reverse engineered for delete plate?
losichu
May 10, 2020 07:45 PM
Hondarian
Apr 22, 2016 11:57 AM
silentnoise713
Jul 11, 2014 10:39 AM
whtsjdm
Jul 3, 2011 09:43 PM
Jimmy101
Feb 21, 2007 08:22 PM
