Official GE Lowering Spring Specs Thread
Old Sep 29, 2015 | 08:35 PM
space egg's Avatar
I bought the ground control coilover sleeves, and they came with eibach springs:
the rates on mine are:
Ground Control
F -.5 to -3.5 in / R -.5 to -3.5 in (range)
F 2.26kg / R 3.6 kg
Old Apr 10, 2021 | 05:29 AM
Rick_a's Avatar
I just installed a set of Godspeed Traction-S springs. They are advertised as:
Average Lowering: Front: 1.0" Rear: 1.2
Spring Rate(kg/mm): Front: 2.65 | Rear: 2.5
I like them better than Swifts, so far. Almost OEM like ride quality with a little more road feel. The car rides flatter than with Swifts and the rear end has better control over bumps. The front doesn't scrape over everything, either.
The front springs are straight rate and the rear springs are progressive.
Old Aug 15, 2021 | 03:18 PM
Greg09base's Avatar
Those Godspeeds look like a great choice. I’m still up in the air on whether I want to do springs or not but after replacing the steelies with 15x7’s the rake is much more obvious. I honestly wish you could get just a rear spring to make it sit level
Old Aug 15, 2021 | 05:15 PM
Rick_a's Avatar
The springs must be done.
I really like them. Aside from slightly decreased ground clearance I see no negatives.
Make sure you get an alignment soon after.
Old Aug 16, 2021 | 11:24 PM
Greg09base's Avatar
The back end settled after a couple days of driving and it’s hard to tell but it might be a little lower than the front now. I need to measure it on a level surface bc my driveway is pretty steep. Looking more for handling than stance but it would constantly bother me if it sat uneven. I’m planning on a progress rsb first so I’ll see how it is after that
photofit77
229
Aug 8, 2013 12:53 PM
Fit_Mike
Apr 24, 2010 06:03 PM
Kurse
Sep 4, 2009 12:18 AM
jazzknight
Dec 13, 2007 08:42 PM
prossett
Dec 9, 2007 10:40 PM
