buddy club and megan coilovers
Old Mar 9, 2011 | 10:26 PM
TW216's Avatar
So. A private seller
Old Mar 9, 2011 | 10:29 PM
SickFit's Avatar
Yea, but he works with LSD Motorsports. He will hook you up with a good price.
Old Mar 9, 2011 | 10:30 PM
TW216's Avatar
Should I.just pm him
Old Mar 9, 2011 | 10:46 PM
SickFit's Avatar
yes sir
Old Mar 18, 2011 | 10:36 AM
TW216's Avatar
Coilovers should be here today will be installing at work tomorrow ill let you guys know what I think.when I get them.on
Old Mar 18, 2011 | 10:44 AM
SickFit's Avatar
Which ones did you end up getting?
Old Mar 18, 2011 | 10:55 AM
TW216's Avatar
Buddy club from xlr8 performance
Old Mar 18, 2011 | 10:57 AM
SickFit's Avatar
Nice! Welcome to the Buddy Club Club lol
Let me know if you need help setting the 16 way adjustable accordingly for daily driving. I think I have mine set to the perfect setting.
Old Mar 18, 2011 | 11:26 AM
TW216's Avatar
What do.u have yours set at its my daily
Old Mar 18, 2011 | 11:40 AM
SickFit's Avatar
Front: 8 Clicks from the furthest right going to the left.
Rears: 13 Clicks from the furthest right going to the left.
You will have a stiffer setting in the front so you can lower your car and it wont rub on bumps as much.
And you will have a softer setting in the rear so it rides much smoother.
You can play around those number of clicks I gave you to your likely.
Old Mar 18, 2011 | 05:46 PM
TW216's Avatar
k just got the coilovers one question the rears are self explanitory now the fronts come with this red aluminum cup piece i know i have to re use the stock upper mount but where would this red piece go ??
Old Mar 18, 2011 | 05:59 PM
  #32
TW216's Avatar
and are there even bumpstops on the front of the buddy clubs
Old Mar 19, 2011 | 09:38 AM
  #33
SickFit's Avatar
Your talkiong about the red annodized cone looking metal that comes for the front correct? I was confused too when I saw it. But its super easy
Ok. So lets start from the bottom up on pieces that will make a complete assembly of your front coilovers:
First - BC Strut Base
Second - BC Shock
Strut Base and Shock already come assembled
Third - BC Spring
Fourth - That red piece facing the cone shape downward(big end down) so that it sits on top of the spring. Its basically you upper spring plate.
Now time to retrieve two piece needed from your stock assembly.
Remove the upper mount which is of course already removable without having to compress the spring. Then for the other piece you need, compress the spring using a spring compressor and take off the black o-ring that looks like a round thick black rubber. (no homo lol).
Going back to your BC assembly.
Fifth - Use the little black rubber ontop of the red cone shape anodized piece we talked about earlier. You will see how they fit perfectly.
Sixth - Use the locking nut to assemble everything up.
Seventh - Place the top rubber mount onto the assembly.
Please make sure to preset your spring load.
If you have any pieces from the BC assembly that are still in the box and have not been used in my steps above, let me know and I will let you know where they go.
Old Mar 19, 2011 | 11:57 AM
  #34
TW216's Avatar
K well see I'm going.there now and how low do you have your front.I have no.idea where to start
Old Mar 19, 2011 | 05:21 PM
  #35
TW216's Avatar
Coiloverss on longest part was trying to adj the front to match the rear rides pretty good much better then. My skunk 2 pro s on my si
Old Mar 19, 2011 | 09:06 PM
  #36
pNz's Avatar
pNz
Came across this vid and thought of this post
YouTube - BuddyClub N+ Damper by HONDA FD1 DIY Video - 01
Old Mar 22, 2011 | 08:03 AM
  #37
TW216's Avatar
Sick fit I can't get my.front to match the back I feel like.the adj knob will.be too.close to the axle if I drop.it the half inch I need to make.it.level
Old Mar 22, 2011 | 09:27 AM
  #38
SickFit's Avatar
It will not hit the axle. How much space do you have between both the spring locking nut and the base locking nut?
I had roughly 1 inch of thread space. and I'm pretty much slammed.
I will PM you my cell number. Maybe you can take pics of the coilover as the setup is now and I can tell you how low you can go to where you wont run and be safe to daily drive.
Old Mar 22, 2011 | 09:30 AM
  #39
TW216's Avatar
I used a 17mm 3/8 drive socket to space between the 2 sets of locks so I could make sure its even.on.both sides but the front measures 21" from bottom of rim to fender rear measures 20.5". I doubt the front will settle a half inch
sukisenpai
Apr 16, 2017 10:37 PM
jdmdc5teg06
Jun 6, 2011 10:52 PM
joggriffin
Jan 23, 2009 01:41 PM
Sam Misled
Nov 24, 2008 01:01 PM
justinfox
May 19, 2007 10:29 PM
