Hawk Brake Pads
Old Jun 14, 2011 | 12:21 PM
Tauwolf's Avatar
Hawk Brake Pads
Hi Fitfreaks. I apologize that I haven't posted this sooner, as I've had this info since April. I just wanted to pass along what I know about using Hawk brake pads on our GE's.
The part number you want is:
(HPS) HB418F.646
or
(HP+) HB418N.646
This pad fits perfectly. It is actually the pad for a 2004 Acura RSX (base model - NOT the Type S)
Only one small modification needed: you need a very good drill bit to drill a hole for the spring pins, as this pad does not have the hole. I spoke with a Hawk bigwig at Mid-Ohio back in April and informed him of this, and advised they could add the Fit to their product line-up if they just added that hole to these pads. I haven't seen any updates to their website, and I was thinking about following up on this in the near future.
Old Jun 14, 2011 | 05:32 PM
teamkitty's Avatar
Great info. I have been using Hawk HP+ (HB418N.646) on my 2009 GE8 for the past 8,000 miles no problems whatsoever. Tirerack actually lists the same two part numbers as you have for the 2007 and 2008 Honda Fits only, but i bit the bullet anyway and found out that they fit GEs fine, too. (i skipped the drilling the hole step that you mentioned above and just left that one bracket piece off--no problems). I was careful to transfer all of the other metal shields/clips/springs from the orig pads plus a slathering of supplied grease and haven't had a squeek or rattle since day one.
Old Jun 28, 2011 | 07:45 PM
The BOM's Avatar
Same here. I'm using HP+ for a 2008 Fit on my 2010 for DD and Autox. I left off the bracket piece as well and have had no issues. Love the stopping power, and they make a light show at night rotors are cheap
Old Jun 28, 2011 | 07:48 PM
JDMchris.com's Avatar
I run THIS
Yup ive been running them without drilling the hole since 2007ish
Old Sep 4, 2011 | 12:55 AM
jjsifo's Avatar
Evening everybody,does anybody know by experience the correct part no. for EBC GREENSTUFF 2011 FIT PADS? I get a DP2891 for approx.$91, and DP22041,for$68 which is considered for now, a special order,less expensive,for reasons unknown.Then i noticed the DP 2891 are for up to 2008.It doesn't sound right the supposedly newer pads are about $30 dollars less,unless they are not really greenstuff,, but OEM. thanks,,JJ
Old Sep 26, 2011 | 12:30 AM
bunz559's Avatar
im sure u have already read it, but ive been doing some research myself and it seems that a few members are confident that the 08 fit brak pads will work just fine.
check out this website, they have a few different brake parts of our GE.
Zeckhausen Racing
Old Sep 26, 2011 | 08:07 AM
jjsifo's Avatar
Brake pads
Check out this website, they have a few different brake parts of our ge.
zeckhausen racing
thanks!!!! jjsifo
Old Jun 9, 2013 | 11:36 AM
CrystalFiveMT's Avatar
I'm looking to get the Hawk pads, but on Amazon they say it doesn't fit the Fit. Why is this?
Old Jun 10, 2013 | 08:58 AM
JazzITup85's Avatar
Don't know, but use either the cr-z or an Acura RSX <non s> to look for front pads. I already did two set of pads & no problems. < green stuff EBC & Hawk HPS >
CrystalFiveMT
Jun 12, 2013 09:45 AM
harlen
Apr 24, 2011 05:42 PM
Marrk
Mar 2, 2011 03:09 PM
TWGE08
Apr 5, 2010 11:20 AM
Nino NoSpam
Aug 11, 2005 09:30 PM
