Progress RSB fit 2012?
Old Jul 5, 2012 | 10:26 AM
silversilvia's Avatar
Hi i was wondering if anyone has fit a progress RSB in a 2012?
the manufacturer's website says 09-11 but i did not think there was any difference to 2012
Anti-roll bars Honda Fit 09-11 Honda Fit Rear anti-roll bar Progress Technology: Anti-roll bars, sport springs, coil-overs, camber kits and more since 1995!
I also sent a email to them, but seeing if i can get a quicker answer here.
thanks
Old Jul 5, 2012 | 11:23 AM
DreaMv's Avatar
Pretty sure its the same. 09-12 is the same platform except for a couple exterior changes in look
Old Jul 5, 2012 | 12:30 PM
Triskelion's Avatar
Just call Progress on the phone and ask......... The CEO is Jeff Cheechov.
Old Jul 5, 2012 | 12:38 PM
zilla8's Avatar
I will have my Progress bar installed in a couple of days on my 2012 sport
I talked to Progress when I ordered it and there is no fitment issue with the 2012
same as 09 and up.There was a issue with the CRZ bar and the GE fit but they changed the part number because the CRZ bar had fitment issues on the Fit. Just make sure to order Part #: 62.1061 and you are good to go.
Old Jul 10, 2012 | 09:11 PM
zilla8's Avatar
Progress rsb installed today with no issues
fit like a champ and I also did Swift springs
best one two punch for the Fit IMO
Old Jul 12, 2012 | 03:57 PM
larrymcewin's Avatar
Put the '09-11 Progress RSB on my base '12 fit the month I bought it. Works great! Fits perfectly.
DO NOT follow the directions which say to monkey around with the shock. Nothing needs to be removed. Just jack up the car and bolt it on (despite what the directions say).
Took less than an hour. Including the time to jack the car up.
Old Jul 15, 2012 | 08:11 AM
BlueBoogers's Avatar
Yep. It can be done without removing the spring, but it's a hell of a lot more difficult with the car on the ground.
Old Sep 20, 2012 | 09:11 AM
Bama3Dr's Avatar
Has anyone installed one of these with the stock suspension and stock springs? I'm thinking about one of these, but don't want to lower the car. Would it make a noticeable difference in handling and stability with everything else stock?
-Dustin
Old Sep 20, 2012 | 09:36 AM
mkane's Avatar
Not so sure it helped understeer as much as rotation during turn in under light braking. Watch out for heavy braking while turning. Fits do spin out.
Old Sep 20, 2012 | 11:13 AM
dustin- get tires first. the weakest link imho on the Fit when it comes to handling, is the tires.
Old Sep 20, 2012 | 12:04 PM
zilla8's Avatar
I did the rsb along with the Swifts and tires at the same time so I can not say for sure
but I think even with stock suspension you will benefit from the rsb.When I pushed my car to the absolute limit the tires were the first thing that needed upgrading
after that you will see even more body roll untill you do the springs and then like magic this little baby transforms.
If you do not plan to lower go with a good summer tire or all season and add the rsb
and you will be set.
Old Sep 20, 2012 | 12:21 PM
Wafulz's Avatar
im hella stock i bought new tires 205/50/16 got rid of that 185 was amaze car handles like a boss now i rather invest that 150 on new tires first if ur on the 185 bump it to 205/50 u will love results
Old Sep 20, 2012 | 01:54 PM
Triskelion's Avatar
I agree with the above replies, but I have had a longer relationship with Progress RSB's than anyone on the forums. I bought the very FIRST Progress bar for the GD3 Fits, and bought the very FIRST RSB for the GE8 Fits.
Regardless of whatever else you do to improve your Fit, start with the RSB. Use up all the tread life your present tires have to give and study the tire info. on the forums to decide what improved brand and size to buy when they are needed. For extra performance, consider lighter wheels if you have the budget. If you stay at stock height, your handling will be significantly improved with the RSB and better tires when needed.
Old Sep 21, 2012 | 12:14 PM
Bama3Dr's Avatar
That is what I'm thinking. I'm definitely planning on upgrading to 205/50/16 tires once the stock Dunlops are worn out. It does sound like the RSB would make a difference even at stock ride height from you guys comments.
The idea of replacing the stock wheels has crossed my mind, but honestly I haven't seen any wheels that I like the look of better than stock (I know, personal preference) and just can't justify replacing them with something I don't like the looks of to possibly shave off a few pounds. The Fit is my daily driver and enjoyable to take the occasional winding back road and push it a little bit, but I'm not looking for maximum performance. Thanks guys.
-Dustin
Old Sep 21, 2012 | 01:51 PM
cjecpa's Avatar
I am doing the progress RSB and koni rear shocks next month. I am also letting my Dunlop tires wear out before replacing i have had my 12 Fit Sport for a little less then 4 months but just about up to 10k since my purchase. I figure stock tires will have maybe 30k life so next year I will need new tires doing the same thing 205/50/16 Continental ExtremeContact DWS.
Old Sep 21, 2012 | 01:55 PM
Bama3Dr's Avatar
I've pretty much narrowed it down to those DWS tires or Kumho Ecsta 4X's. I'm leaning a little more toward the Kumho's because I've seen a couple of posts about getting a little better gas mileage with those where most people say that gas mileage either stays the same or drops a little with the DWS's in the 205/50/16 size for both. Everything I've read seems to indicate that the two are pretty comparable in most aspects other than that.
-Dustin
Old Sep 21, 2012 | 02:57 PM
cjecpa's Avatar
They look pretty much the same in the surveys on Tirerack. Usually it comes down to when I buy if Continentals has a rebate or sale at the time I need them. The spread between the two is about $100 and about 10k more miles with the warranty for the Continentals.
EQB356
Aug 9, 2012 08:16 PM
RevToTheRedline
Apr 30, 2012 04:51 PM
Vtecguru
Aug 26, 2011 11:35 AM
IN2TURBOS
Feb 22, 2010 06:56 PM
FrumiousBandersnatch
13
Feb 17, 2010 06:34 PM
