Aftermarket Suspension?
Old Mar 22, 2015 | 04:38 PM
glockprime's Avatar
Originally Posted by mahout
we've found the best handling Fit are those with:
6. good alignment, typically toein 1mm each side front zero toe rear with the camber and caster from 1 to 1.5" drop.
mahout, why would you recommend front toe-in for the understeering fit? btw, rear alignment is not factory adjustable
Old Mar 22, 2015 | 08:37 PM
mahout's Avatar
we find that toe-out, typically for FWD nose heavy vehicles, like the Fit, just scrubs in corners. and especially when compared to Fit with front ASB disconnected or added rear ASB. It could be there is enough compliance in the front suspension to back toein to neutral or even a little toe out. it ain't no porsche. one mm, 0.040", isn't much toe in.
do we have lots of data? not really, just the a/x results and race laps on successful cars.
as for rear suspension, we set camber and toe with shims on the hub back plate. its time consuming but when necessary we do it. I wonder if the racing bottom feeder class does anything. but even then the mazda 2 chassis appears so superior it wouldn't matter.
you have different results?
there's lots of vehicle detail prep tbat isn't noticed by the specs. yes, many require no changes from OEM but they have almost no chance of being detected. talk to some competitors in showroom stock racers in private. no body is really OEM stock from suspensuon to chassis to 'freshened' engines..
MEATBABY
Dec 9, 2014 10:09 PM
dotkayk@yahoo.com
Aug 17, 2012 11:52 PM
luv4jdm
Feb 2, 2009 03:48 AM
shonda1989
Dec 9, 2008 10:16 AM
Enzo Wagon
May 8, 2008 01:45 AM
