Koni strt and Eibach springs
Old Apr 18, 2016 | 08:56 PM
FitIsGo85's Avatar
I was browsing tirerack and saw a suspension package using Koni strt shocks/struts and Eibach pro kit Springs for 487. Is this a good deal and do you think it will be a decent ride for a dd? Should I spend the extra roughly 100 dollars and just get swift springs instead? Here is the link to tirerack. http://http://www.tirerack.com/suspension/suspension.jsp?make=Koni&model=STR.T+Damper+Set+%2 6+Eibach+Springs&group=STR.T+Damper+Set+%26+Eibach +Springs&partNum=1125-1029&autoMake=Honda&autoModel=Fit&autoYear=2011&au toModClar=Sport
Old May 20, 2016 | 04:35 PM
dayshay's Avatar
i got this package installed about a month ago, along with a progress 19 mm rear sway bar. totally transformed the car, feels like little go cart now. get the camber bolts too for around $25 and set it to negative 1.75. good luck.
Xtina
Mar 15, 2015 11:49 PM
aallbbeerrtttttt
35
Nov 18, 2009 11:23 AM
alex020277
Apr 24, 2009 03:43 PM
SNOW
Feb 10, 2009 08:03 PM
spoonek4
13
Jan 21, 2008 01:53 AM
