wheel question? tried search
Old Jun 17, 2010 | 11:17 PM
kevinkidstar138's Avatar
seems like everyone always states I WILL be lowering the car, so waht will rub?
but
I really want to get the Drag DR-23 16x7
i will not be lowering the car, at least not in the anywhere near future lol. have 4 people in my car all the time and with chicago roads it just seems like lowering would be a headache
so with that being said will these wheels fit with no rubbing issues and will they fit the stock tires or will i need a diff size tire too?
i dont know the offset either, wheel noob here
Old Jun 17, 2010 | 11:28 PM
Btrthnezr3's Avatar
Offset probably needs to be around 45mm but some have run 40mm with little to no rubbing. There are debates on tire size but closest to our stock diameter is 205/50/16. Hope that helps.
Old Jun 18, 2010 | 04:04 AM
thefit09's Avatar
Well I only rubbed at highway speeds over bumps and on hard turns with a 2" drop and stock tires on 16X7 +40, so I'm sure you'd be fine a stock height with an offset of +40 and probably +35. If you get lower profiles, like 205/45 you'd be even better off.
Old Jun 18, 2010 | 11:28 AM
thanks, i think the dr-23 is a 40 offset so on stock suspension and stock tires i should 80% sure be good and with 205 tires i would be even better
correct?
Old Jun 18, 2010 | 11:37 AM
FitDEEZ's Avatar
7 inch wide rims would fit better with a 195 less chance of rubbing aswell
Old Jun 18, 2010 | 03:23 PM
ok they are 16x7 +40 and im going to run them with the stock 185/55-16 tires, stock ride height
will it rub? would a 15" be better with the 185 tires?
im so confused.....now thinking about it if i have more than 2 people in the car doesnt that pretty much act like lowering springs haha...is a minor rub that dangerous?
Old Jun 18, 2010 | 06:36 PM
FitDEEZ's Avatar
U can use the stock 185s sice it would be cheaper and u can have ur car Packed and 5 people including u and won't rub at stock height or with a 2 inch drop
Old Jun 19, 2010 | 05:20 PM
so even with the +40 offset im ok, fitdeez experience with this?!!
Old Jun 19, 2010 | 05:23 PM
btw fitdeez your car is supppper clean!!
Old Jun 19, 2010 | 11:13 PM
FitDEEZ's Avatar
Thanks, and u should be ok with them
Old Jun 19, 2010 | 11:42 PM
bmxman's Avatar
yeah you will be fine, I run on 17x7 40 offset drag wheels with 205/45 tires and I'm dropped on sportlines with no rubbing at all.
Old Jun 20, 2010 | 07:52 PM
are drag good wheels bmxman? you like them
Old Jun 20, 2010 | 08:24 PM
Gbaby2089's Avatar
drag wheels are junk
IMO
if you're going to get knock-offs get Rotas....much better quality if that is possible for a cheap wheel
although personally if i were you i'd eliminate shipping and buy my wheels
for around the same price as drags/rotas/etc.
isis07734
May 15, 2012 04:16 PM
ccl088
Aug 1, 2011 09:41 PM
tokenasianguy69
13
Sep 2, 2010 01:11 PM
ds62987
Dec 15, 2008 09:36 PM
Sugarphreak
May 27, 2008 10:50 AM
