Fitment Help 16x7 +40 offset
Old Nov 5, 2010 | 09:21 AM
JDM-Taffeta-S's Avatar
Hello, Someone please help me if they have this set up I am on t1r lowering springs and Im looking to put these wheels? Will they sit pretty flush? Will i rub ? and what tire size should I run ? thanks guys any help would be great.
Old Nov 5, 2010 | 09:42 AM
Cl9lover's Avatar
You should be fine man...
I would run a 195/40 or 205/40
I cant wait till I get my wheels on :P
Old Nov 5, 2010 | 10:56 AM
!bungle's Avatar
Tire Rack shows only 1 tire in 195/40/16 - the Yokohama S.drive.
It has an overall diameter of 22.1, while stock 185/55/16 tires are 24.2 - that's over 2 inches shorter, and will play havoc with gearing, ride height, and sidewall protection for alloy wheels.
There are 6 tires in 205/40/16, giving a better selection. But the B.F.Goodrich g-force T/A KDW 2 (the best rated) has an overall diameter of 22.4, which still is too small, IMHO.
Maybe you were thinking he had 17" wheels? Then a 195/40/17 is 23.1 in diameter - not too bad, and a 205/40/17 is 23.5 - even better.
Old Nov 5, 2010 | 11:07 AM
Cl9lover's Avatar
I assumed you were lowering it =/. Sorry!
205/40/16 is perfect for my set-up, especially since my fenders will be flush with the lip of the wheels... To each his own though mate
If the wheel is a lower offset then stock, and rubs, smaller tires are the only way to go...
Go with Toyo Proxes if you decide on 205/40 - Great tires!
Old Nov 5, 2010 | 11:25 AM
!bungle's Avatar
He is lowered and may want/need to go with the sizes you recommend, I was just mentioning possible negative side effects... that's why I added the IMHO!
Old Nov 5, 2010 | 11:28 AM
Cl9lover's Avatar
IMO - The only neg. effects of running a smaller tire is the spedometer being off... Other than that, all is normally fine Now I can list a LONG ass list of reasons not to lower your car, but I still do it anyway
Old Nov 5, 2010 | 12:02 PM
johnkimble's Avatar
It also affects final drive and like bungle said the protection of the wheels.
Now if you care about style more than those things, then you know which way to go lol
Old Nov 5, 2010 | 12:13 PM
Cl9lover's Avatar
Form > Function
Old Nov 5, 2010 | 02:22 PM
doctordoom's Avatar
Supervillain
Form > Function
hahah sometimes it is, but other times, Function > Form.
is it wrong to appreciate both?
Old Nov 5, 2010 | 04:36 PM
Cl9lover's Avatar
Depends on the vehicle :P... For a Supra or high performance vehicle Function > Form... For a Fit or any other economical car where performance isnt really attained - Form > Function
Old Nov 5, 2010 | 08:02 PM
beangrower's Avatar
running 205/45 w/ 16x7" +35 on buddy clubs. no rubbing...sorta flush. u should have no problems if ur gonna run t1'r's.
Old Nov 6, 2010 | 09:47 AM
Thanks to all the help to each and every one of you. Great pics beangrower. Keep the pics coming maybe of similar setups. In my case i dont understand im on t1r but i rub and im on stock wheels with upgraded 205 50 16 tires.
Old Nov 6, 2010 | 01:40 PM
Klasse Act's Avatar
Thumbs down
Someone posted about the BFG KDW2's being "best rated" by Tire Rack, well, when they're relatively new, yeah, but when they get some miles on them the car sounds like it needs wheel bearings, even my g/f who knows nothing about cars noticed how loud they were, terrible tire....no more
Old Nov 6, 2010 | 04:13 PM
!bungle's Avatar
Yeah, I know the Tire Rack "best-rated" doesn't mean much. I personally wouldn't consider them because they're so freakin' heavy, anyway!
At 22lbs each in 205/50/16, that's 3lbs more than the Conti DWS, and that's at the outer edge of the wheel/tire combo - where it has the most negative influence.
For the Fit, we need every performance tweak we can get since there are so few engine mods available. Less rotating weight is a great place to start.
Old Nov 7, 2010 | 11:04 AM
Good info. I doubt you need new bearing on your ge already. How many miles are you on ?
Old Nov 13, 2010 | 09:51 PM
Hey guys what do you think about the volk ce28n honda time attack edition? 16x7 +45
Old Sep 18, 2011 | 04:12 AM
Tong213's Avatar
hey great fit ment
i have a question though
did you need to do anything to get no rubbing, like fender rolling anything like that?
Old Sep 19, 2011 | 12:44 AM
alpineguy's Avatar
you wont rub at all and run a 205/45/16 tire so you speedo wont be out.
Old Sep 19, 2011 | 11:56 AM
Tong213's Avatar
perfect!
this helps alot, thanks
Old Oct 4, 2011 | 06:15 PM
TW216's Avatar
I have 16x7+40 wheels on my fit 195/50/16 kumho asx tires I'm on buddy club coilovers and I just had too cut my fender liners up front and my rear rubbed when I had the coilovers all the way down so I raised the back 6mm now the car is level and i have no rubbing problems anymore and my Camber is about -1.3 all the way around
Theos92vr4
Mar 12, 2012 01:32 AM
khanhdom
Sep 27, 2008 07:06 PM
AtticusFit
Jun 21, 2008 12:55 AM
MNfit
Mar 14, 2008 04:32 PM
lilcat
Jul 23, 2007 10:24 PM
