InstaJACK JS-1000
Old May 13, 2011 | 10:24 PM
phenoyz's Avatar
Old May 14, 2011 | 02:51 AM
neil patrick harris's Avatar
unfortunately, i did.
great idea but it just doesn't work very good. i got the combo w/ the wrench as well and that died almost instantly. you can hear the motor working but somewhere in the "drive train" there's a broken disconnect because it doesn't spin the spline. i used the jack a few times and then that failed, too. i had to use our stock scissor jack to lift my car enough to get the failed instajack from under the car. if it fails trying to lift our relatively light cars, you should look elsewhere for something reliable. and anyway, i still had to drive over a 2x4 piece of wood to get the instajack under the car so it was kinda pointless. i ended up getting a nice low profile jack from harbor freight that i'm so much more happier with and i feel that it's so much more safer.
Old May 14, 2011 | 12:18 PM
phenoyz's Avatar
Thanks a lot. I almost bought this.
Looking for a good wrench and jack to bring for some
long driving just in case.
Gonna shop again.
Old May 14, 2011 | 03:00 PM
that setup wouldn't have been very portable anyway. it comes in a pretty big, hefty case. i don't think there's a good portable solution except for a hydraulic bottle jack but i don't like those things. i'd prefer to just use the insurance that i pay for. if need be, i can use the included jack w/ some sort of base for it to be more stable on the side of the road.
Old May 14, 2011 | 05:39 PM
feddup's Avatar
standard
Believe it or not IF you use the Fit's designated jack points the scissor jack that comes with the car works beautifully. I've used it probably 30 times without event. Use common sense with it of course.
SilverEX15
Sep 26, 2017 08:55 PM
secondspassed
Dec 28, 2009 04:50 PM
mozarwasagenius
Apr 22, 2009 10:10 AM
halfmoonclip
Apr 10, 2009 09:50 AM
GD3_Wagoon
Nov 11, 2008 12:25 PM
