195/50/16 or 195/55/16
Old Aug 7, 2011 | 05:28 PM
SenBlue09's Avatar
OK, so i have narrowed my tire search finally to two sizes! Took me long enough...
I dont want as much of a gap in fenders so i may go with the 195/50/16 (Kumho Ecsta ASX $77 each!). They should be lighter too. Im lowered on Progress Springs which is only about a 1.2f/1.0r drop, so im sure rubbing wont be an issue, especially on my local roads. If anyone can help me justify going to 195/55/16 than i would chose the Nexen CP671 ($71 each!). Oh yeah, 205's have been scratched off my list.
Any suggestions?
Old Aug 7, 2011 | 06:34 PM
fitisbamf's Avatar
i have a thread about my 17's with a 205 u shouldnt rub with 16's im running 215 40 17 they rub but im pulling the fender. anyway if u run 195s (i had them on 15's) then u shouldnt ever have a problem. im lowered 2.5-3.5 in. and i never had issues with rubbing on smaller rims
Old Aug 7, 2011 | 06:39 PM
SenBlue09's Avatar
thanks. Im keeping the stock sport rims, which i think are only 16x6, so i feel the 205' might sag a bit, and plus they cost more.
Old Aug 7, 2011 | 06:49 PM
Hootie's Avatar
The only real benefit from having a 195/55 opposed to 195/50 is that the 55s will have a thicker side wall (great for absorbing the initial shock from bumps and softer ride) and it will fill your wheel wells more due to having a larger outside diameter (which will also hinder your acceleration).
The shorter 50s you'll have a slightly stiffer ride in general due to the thinner sidewall (also helps during cornering) but the outside diameter will be slightly smaller than the 185/55s that came on your Fit. So, this would actually help your acceleration as well.
I wouldn't be too concerned about rubbing if you are using your factory Sport alloys. Now if you had aftermarket wheels then it could rub depending on the wheel's width and offset.
Old Aug 11, 2011 | 08:52 AM
SenBlue09's Avatar
thanks +1 rep. i think i may go with the 195/50's. im hoping the ride comfort wont be that much worse than with 195/55's.
Old Sep 1, 2011 | 01:29 PM
R..F..G's Avatar
Are you goin to lower your car??
Old Sep 1, 2011 | 04:18 PM
Bthasht's Avatar
^^Car is lowered read the thread.
Off that 195/55 will get rid of a little more of that gap you got there. I just looked at your thread in your sig for reference.
Also I liked the wheels better in Bronze. Just my two cents....
Old Sep 1, 2011 | 05:54 PM
thorton0's Avatar
i would go with the 55's
Old Sep 22, 2011 | 08:49 PM
Cornerstrike's Avatar
Did you purchase the new tires already? Im very curious to know what 50s look like with stock wheels and a drop, since Im contemplating that myself.
Old Mar 21, 2013 | 06:42 AM
Alan3885's Avatar
I was also thinking about going with the 195/55/R16 because even the CR-Z which shares the same platform as the Fit comes stock with the 195/55/R16 sizes and would this size cause any rubbing or issues to the vehicle?
Old Mar 27, 2013 | 11:41 PM
zilla8's Avatar
you will be fine at stock height with 195/55 and maybe a mild drop.
op is on progress springs that are about the same as Swifts.
I run a 205/50/16 on stock sport wheels with swifts and do not rub under any conditions.
the 195/55 is 24.4 and the stock Dunlops are 24.2 so the CRZ tire is just a little taller no problem.
sabawballs
Oct 30, 2014 12:16 PM
Nio4
Jul 2, 2013 10:45 PM
AtticusFit
Oct 11, 2012 10:16 AM
madvetos
Dec 1, 2011 09:22 AM
dewthedew
Dec 13, 2008 08:25 AM
