Wheel Spacers
Old Dec 19, 2012 | 11:01 AM
BlueBoogers's Avatar
Those spacers are wide enough to be used as wheels!
Old Dec 19, 2012 | 04:13 PM
Dookoo's Avatar
The Ichiba's arrived. I'll try them out tonight for fitment.
Old Dec 19, 2012 | 04:59 PM
Subie's Avatar
Originally Posted by Dookoo
I'm sorry I ever started this thread
Welcome aboard D!
Old Dec 19, 2012 | 06:39 PM
Dookoo's Avatar
Originally Posted by Subie
Welcome aboard D!
Ahhh, someone who knows my pain. What part of Ca? Here's a pic you might enjoy of my STI. FMIC, Garrett GT35-R, 530 AWHP.
Old Dec 19, 2012 | 07:29 PM
Dookoo's Avatar
With the Ichiba V2's, the weight of the vehicle is supported by the hub, not the lug stud/nuts. There are dedicated studs built in so the issue of having lengthened studs is mute. The issue of bearing loads always comes up but I've never had a single issue with decades of experience with hubcentric spacers on and off the track.
Old Dec 20, 2012 | 07:42 PM
Dookoo's Avatar
Pics 20mm offset
The 20mm offset looks fantastic with no rubbing, even on a bouncy dirt road. I will keep the 20mm for the front and go 30mm for the rear (ordered). Name:  nospacer_zps0ec05706.png
Old Dec 20, 2012 | 07:44 PM
Dookoo's Avatar
And here's a pic with 20mm offsetName:  spacer_zpsa63d2076.png
Old Dec 20, 2012 | 09:34 PM
BlueCell's Avatar
Looking good. I run 20mm spacers on my GD3. Pretty much the same kind. It's been almost 2 years with no problems. You're lucky ur fenders stick out more, jelly.
Old Dec 21, 2012 | 11:35 AM
Subie's Avatar
Very nice D! Mine's all stock. Just upgraded hoses and brakes. I'm just north of you.
Old Dec 29, 2012 | 02:56 PM
Dookoo's Avatar
Finished. 20mm front and 30mm rear Ichiba's
Old Dec 29, 2012 | 02:57 PM
Dookoo's Avatar
Installed Pics. Nice clean/flush look.
Old Dec 29, 2012 | 11:20 PM
  #32
mahout's Avatar
There are many Fits which are running 35 offset with no rubbing. The ones who are rubbing have lowered suspensions. I'm staying stock ride height. Even my Subaru STI has Ichiba V2 hubcentric's with 25mm front and 35mm rear offset. It also runs on Tein Superstreet coil overs with no issues and years of track abuse. I believe that many of you are assuming that a spacer is getting sandwiched beween the hub and the wheel, which isn't the case as the V2 is bolted directly to the hub. Its a quality machined part that is time tested for durability and strength. I'll post pics of the 20mm offset when they arrive, hopefully by the end of this week.
I disagree with the Fits running 35mm offset unless they are running tiny tires. My Fit has 40mm offset 17x7 wheels carrying 195/40x17 tires and barely clears even though not lowered. We had one here today with 38mm and needed to see what we could do to prevent his constant rubbing. A Subie will tolerate 25/35 mm but not a Fit unless small tires or stiff springs are employed.
A spacer is always sandwiched between the hub and wheel; those that bolt on the hub and then have the wheel bolted to the spacer is almost always thick as !" or greater (25.4mm). The plate spacers merely fit between the hub and wheel and come in thicknesses from 1/8 to 1/4" (3 to 6mm) and require at most longer lug bolts to ensure enough engagement of nut to threads. On a Fit whenever you asdd spacers the thickness is subtracted from the original offset.
We have used thinner bolt type spacers but they were carefully matched hubs to wheels to ensure enough bolt strengths and were used to reduce chevy wheels with substantial offsets (like 50mm)to more reasonable offsets like 35mm.
From the looks of the photo you're really talking about the thickness of the spacers, not offset; that is a greatr difference. The fronts then would be 53-20 or 33mm offset and 53-30 = 23mm offset in the rear. And I don't believe you not getting rubbing. Have you measured the actual thickness of the spacers? Again, from the photo the thicknesses look like 15 mm and 20mm.
Old Dec 30, 2012 | 12:06 AM
  #33
Dookoo's Avatar
No rubbing. Even fully loaded with passengers. Yes 20mm and 30mm spacers so roughly the equivalent of 35 and 25 offset wheels. My STI rubs but it's also lowered 1-1/2" on coil overs. I measured and they were rougly .75" and 1.2" If I lowered the Fit, it would rub for sure.
Old Dec 30, 2012 | 11:46 AM
  #34
mahout's Avatar
What size tire are you running?
Old Dec 30, 2012 | 11:58 AM
  #35
Dookoo's Avatar
Stock OEM tire and wheel
Old Mar 19, 2013 | 05:38 AM
  #36
Golfer's Avatar
Very nice! I wish you could report how they do with a drop.
Old Aug 20, 2014 | 12:15 AM
  #37
alfarop1999's Avatar
Any issues with ur wheel spacers? 20mm front and 30 mm rear?
Old Aug 20, 2014 | 08:34 PM
  #38
FIT-tles Worth's Avatar
Dude.... Really? It's from 3-19-2013 lol
Old Aug 20, 2014 | 09:37 PM
  #39
mahout's Avatar
Not enough funds for new wheels at the moment but I wish to give my Fit Sport a bit more stance. I'm about to purchase a set of Ichiba hubcentric spacers, 20mm front and 32mm rear. I am stock suspension with OEM alloy wheels. I am not planning on lowering due to living in the country with lots of steep driveways and road conditions which will destroy my front end. Anyone see any fitment issues or perhaps another size?
Spacers are a prolem for most. If you take the thickness of the wheel spacer and subtract that from the wheels offset too often the offset is too little. If you put 1" spacerson stock 55mm offset wheels you essentially make the offset 30mm which pushes the wheel too far out and invites not only interference but bearing damage or even failure. The lowest accetable offset is 45 mm so generally 10 mm spacers are all thats possible, even with extended wheel studs.
You're best bet is 6 mm (1/4") spacers which widen track about a half-inch and well worth the $50 cost because it also produces a little more camber, always welcome).
Old Apr 22, 2024 | 12:35 AM
  #40
Pseast's Avatar
Originally Posted by Goobers
I guess, ultimately, 205s on a 16x7 wheel with +43 offset is the same as using stock wheel and tires with a 20 mm spacer. Well, in terms of lining up with the body.
https://www.fitfreak.net/forums/974182-post2000.html (as you can see from the post) the pictures were taken in march of 2011... but my setup is still the same now.
I kinda wish that my fronts sunk back in about 5 mm... I don't like that it sticks out.
The rear on the other hand... I wish came out a touch. But I guess it's fine as is.
Oh, I am "lowered" on Swifts.
I'd love go see the photos, unfortunately, the photo isn't showing in that post anymore... Do you still have any?
vbpsport
Nov 8, 2011 11:32 AM
mugenfit79
Mar 21, 2011 02:42 AM
MIAMIFIT
Apr 6, 2010 01:06 AM
KoolMikeSki
Aug 9, 2009 09:15 PM
heymikesays
Oct 25, 2006 09:50 AM
