3rd Gen GK Specific Fit Engine Modifications, Motor Swaps, ECU Tuning Sub-Forum Threads discussing engine mods/swaps/tuning for the third generation GK Honda Fit.
J's Racing GK5 B-Pipe or Mid Pipe
Old May 15, 2018 | 06:35 PM
evilchargerfan's Avatar
so, a custom made mid pipe .... you'd say may perform just as well as the j's racing b pipe?
Old May 15, 2018 | 09:44 PM
Myxalplyx's Avatar
Yes! And that's not saying a lot. I'd say you wouldn't/shouldn't change out the mid pipe at all. It may not be worth it for 99% of the people here. Biggest bang for the buck is changing out the stock muffler for a straight-through flowing one and if you really want to change something else, a freer flowing cat converter.
Changing the mid-pipe I could see no significant difference in my 1/4 mile times. It was small.
Old Mar 25, 2023 | 04:56 PM
Wht_GK5_Tx's Avatar
I just bought a HKS Hi Power (carbon tip) for my 19 sport and mated that to a 2inch resonator delete midpipe and now I have lost power. It sounds cool but, where did I go wrong?
should I have just done the resonator delete alone?
should I have a mid pipe from j’s or Spoon?
and what diameter is stock again so I can do a res delete on stock pipe.
Old Mar 26, 2023 | 10:34 AM
NWCH's Avatar
You should have kept the OEM mid pipe. Put your resonator back in and the car will drive just fine because you actually need some back pressure on smaller engines. You can't just sraight pipe cars and gain usable HP.
Old Dec 22, 2023 | 12:43 AM
SLIPNFIT's Avatar
high flow cat stock b pipe no muffler and you'll be good.
Old Dec 22, 2023 | 04:41 AM
elkaku's Avatar
Did you tune the car after.....?
If not, there's probably the problem.... Mods like this will probably require a tune...
Old Dec 22, 2023 | 07:07 AM
Wht_GK5_Tx's Avatar
I ended up going to a 1.75in pipe. That fixed the problem and still sounds good.
Myxalplyx
Mar 24, 2021 11:15 PM
tweezy312
30
Mar 17, 2015 10:16 PM
FittinglyFittedFit
Mar 10, 2015 09:49 PM
DarkFit
Oct 7, 2009 10:28 PM
t3chn0rav3rb0y
Nov 19, 2007 08:43 AM
