3rd Gen GK Specific Fit Engine Modifications, Motor Swaps, ECU Tuning Sub-Forum Threads discussing engine mods/swaps/tuning for the third generation GK Honda Fit.
Air Con Bypass
Old Feb 16, 2016 | 11:26 PM
jhn's Avatar
jhn
Air Con Bypass
Anyone bypass the air conditioning on a GK with a shorter belt?
What length belt did you use?
Old Feb 17, 2016 | 03:37 AM
Myxalplyx's Avatar
I do not know the exact length but since you are interested, you can order it from Japan from J's Racing.
https://www.jsracing.co.jp/js2/index...=51&xSHASHU=39
I'll translate it for you best as I can.
"Such as in the air conditioning compressor racing car and run meeting vehicle alternator belt be required at the time of removal.
Necessities of air conditioning non-mounted vehicle can be fitted without removing the air conditioning compressor is also in air-conditioned vehicle is perfect for users who want the power up to reduce the load even a little. (Because it does not work is that when air conditioning Please note) corresponds widely from the street to the circuit traveling. Regardless of the category is a required item of "those who want to win."
Old Feb 17, 2016 | 08:35 AM
jhn's Avatar
jhn
I can only imagine what that cost to have shipped!
I suppose I can do the string measurement thing, but I wanted to check first to see if someone knows off-hand.
Is there a Canadian version offered without air conditioning? Maybe I can get the belt length from there.
I know there's not much gain but if I can find the right length at the local APS, it's a cheap, easy swap. No big loss either.
Mshellt
Jul 12, 2016 04:23 PM
Solscud007
Jul 15, 2013 04:36 PM
dewthedew
Dec 30, 2008 01:20 AM
2K8SPORT
Jul 29, 2008 05:30 PM
ezduzit
May 30, 2008 06:14 PM
