3rd Gen GK Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 3rd Gen GK Honda Fit
Question about the grille trim
Old Oct 5, 2023 | 12:26 PM
FITforduty117's Avatar
Removing H emblem without breaking tabs
I have a 2015 ex i want to paint the chrome emblem red to match my trim piece but i was wondering if there is a way to remove it without having to break the tabs so i can paint it and just out it back on
Old Dec 20, 2023 | 09:50 AM
Reel's Avatar
I wrapped mine with a vinyl wrap! Not a permanent fix, but it works! Look up "chrome deletes" online, people typically do black, but hey, all colors work. It's extremely tedious, but no need to remove the emblem
Old Dec 20, 2023 | 10:35 PM
Virulence's Avatar
I have painted my emblem black recently. I will guide you.
First, you must remove the grille. In my 2019 the grille style is different. You may or may not need to remove the bumper to remove the grille.
Once the grille is off you will see the back side of them emblem. On the back side there is little metal rings that are capturing a plastic stud which is part of the emblem.
If you are extremely careful you might be able to pry the metal ring off the stud without braking the stud. I was not so lucky, however. I did break the studs in the process of removing the ring. As a result, I recovered the broken pieces of the stud and superglued it back together after removing the emblem. This will require you to sand it smooth once the glue is tried. When sanding, be gentle as to not break the stud once again. Once the emblem is painted and studs are repaired you can then replace it as normal.
GoBucky
Jul 28, 2015 08:38 AM
tinctorius
Jun 28, 2012 07:56 PM
dgs
Jul 20, 2009 11:27 AM
jimrb66
May 12, 2009 08:04 PM
wait4thefit
Sep 11, 2008 10:13 PM
