3rd Gen GK Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 3rd Gen GK Honda Fit
HID head lights
Old Oct 13, 2014 | 12:18 AM
Vtecfreeak's Avatar
HID head lights
Has anyone hooked up hid's on there GK yet?? If u did what did you do for the day time running lights.?
Old Oct 13, 2014 | 12:49 AM
payluder's Avatar
you can pull fuse number 25 under steering column to disable the DRL.
Old Oct 13, 2014 | 01:20 AM
NotBlake's Avatar
Does this disable any other system or is there literally just a DRL fuse? I assume the high/low beams still work with this fuse pulled?
Old Oct 13, 2014 | 01:33 AM
payluder's Avatar
It only disable DRL everything else works as normal.
Old Oct 13, 2014 | 08:40 AM
Vtecfreeak's Avatar
Cool thanks for the info.
Old Oct 13, 2014 | 08:42 AM
Vtecfreeak's Avatar
But dose it effect the auto on and off for the headlights??
Old Oct 13, 2014 | 06:08 PM
payluder's Avatar
No I do not believe it will effect the auto on and off. With my fuse pulled I have used auto on and off and it works still though I would recommend you not to use auto off and on with aftermarket HIDs kit because it will only shorten the life of the ballast.
Old Oct 14, 2014 | 04:50 PM
noripwr's Avatar
Auto on and off still works, but I don't think it will auto off at night the HIDs when u turn off the engine and lock the car. So be cautious of the lights to make sure you don't accidentally drain the battery
j5ive
Canada Fit Forums & Clubs
18
Sep 16, 2014 01:52 PM
EUROz*JDMz
Apr 10, 2014 09:52 PM
misha775
Apr 1, 2014 11:59 PM
manny3672
Mar 14, 2012 10:57 PM
panda1314
Jan 13, 2009 02:57 PM
