Cadillac Horns
BACK TO THE ORIGINAL TOPIC!!
I have the Cadillac 4-Notes on my Protege5 and miss them when I drive my Fit. I was thinking about getting some ($14 to pull them from a local junkyard myself), but I have no clue where to mount them. I would for sure do a better job wiring them, but this is what I did with my Mazda but don't know if this would work with the Fit (on radiator support behind grille).
I was hoping to be able to mount them facing forward like they were in the car I pulled them from, but there wasn't enough room, much like in the Fit. Mounting suggestions?
Remove the original horns behind the bumper and put them there. Someone posted pictures. That's what I'm going to do with the horns I got from College Hills Honda.
I'm slowing connecting the wires for my trailer hitch lights. I'm surprised at how thin the wires are that run to the lights, and there's not much room to tap into them.
I just received these sport horns, but no directions on installation, just an update about using only 1 bracket per horn. Too cold to try to install anyway.
I didn't use the brackets that came with the horns. I used the factory brackets like recommended in the video. Follow the video link and it is relatively painless.
Note: Guy in the video has a hoist and this makes it much easier to get underneath to remove the pushpins. If you don't have a hoist, I recommend oil change ramps at the least, or put it up on jackstands.
Bill #22335
Thanks for your post. I will watch the video and take notes. I have ramps, they came in handy installing the CURT trailer hitch. I have trim removal tools that may help. I just installed the Phillips Extreme +130 headlight bulbs. They are definitely brighter. Decided to just pull the fuse for DRLs using these bulbs.
Bill #22335
Bill #22335
As for standard replacement bulbs, I saw a comparison, and the brighter they are, the sooner they burn out. You might want to carry spares.
My son got stopped by a cop because a headlight was burned out. He had to repair it and bring the receipt to the town hall within 24 hrs. Since I always keep bulbs on hand, I didn't have a receipt. We went in, and I showed the town clerk the packaging for the bulb. She wanted a receipt. I finally persuaded her to come out and see the bulb in operation. Sometimes rules can be ridiculous.
SilverEX15
Jun 16, 2015 08:23 AM
Sacman
Apr 22, 2014 04:06 PM
Diasoul
Dec 2, 2012 09:54 AM
FELIXY69
May 10, 2010 11:25 PM
