3rd Gen GK Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 3rd Gen GK Honda Fit
Has anyone painted the rear, upper tail light/reflectors?
Old Mar 7, 2018 | 10:16 AM
ercdvs's Avatar
That is an option, but now I am reconsidering the light replacement there as well.
Old Mar 8, 2018 | 02:53 AM
Amabento's Avatar
Originally Posted by Eddiev8
Saw this pic on insta literally before i saw this post and i was like perfect! It looks good in my opinion and you can probably take them off and use some VHT night shades or plastidip
Up to you.
Pic by tfc_koichi<br/>And tomomixx57's gk5
Thanks for posting this... it answers the question of whether going with a black wrap to match the black pillars around other windows would work. Even the front windshield has the black on either side... this is encouraging. I dig the added touch of tinted film on the reverse center light, but mine is an EX (The chrome is designed to line up with it). I’d tint the lights all around or none.
Old Mar 8, 2018 | 03:30 PM
wasserball's Avatar
Originally Posted by nisco
I removed both pieces (two 8mm nuts on each side,) washed with dish detergent, let dry, wipe with rubbing alcohol, laid the vinyl, and heat treated with heat gun. Heat gun should be used for setting the shape at the end not during in order to prevent excessive stretch in when laying down the vinyl. Make sure to cover all the clear red plastic, when you open the hatch side portions of the reflector are visible and look bad if not covered with vinyl.
I released the two 8mm nuts, but there seem to be some interference that prevents the reflector from coming out. I don't want to force and crack the reflectors if I use brute force. What is the technique to get the reflectors out?
Old Mar 8, 2018 | 08:33 PM
Fuelish's Avatar
There's the 2 nuts, and there's a "pin" "clip" kinda thing (for lack of better words) into the hatch...gentle upwards wiggling should free it easily...I gently tapped up on the threaded shafts with a small wrench and wiggled a bit. It's easy enough to get 'em off
Old Mar 9, 2018 | 12:38 AM
wasserball's Avatar
Thanks. So, there is some alignment dojigger that is keeping the reflectors in place.
Old Mar 9, 2018 | 07:21 AM
Fuelish's Avatar
Correct....it does seem more for alignment than actually clipping in. I thought it was gonna be troublesome when I did an initial test-run of removing them, as it didn't seem like they would come off. Put 'em back on after that, took 'em off again a few days later when I actually had the time and the PlastiDip, and it's really quite easy, in the scheme of things once you take into accout those "pins" - one per side. This was my first experience with PlastiDip, and dunno if it's the nature of the product or my shoddy spraying, but it came out with a slight textured appearance, almost mimicking the plastic dashboard texture subtlely. Definitely worth the $7.99 can and a bit of time if those red trim pieces annoy you as much as they did me
Old Feb 9, 2019 | 12:39 PM
Spyke's Avatar
Not painted, but I did remove them and wrap with gloss black, I like it and I can spot ours very easy that way.
Old Mar 23, 2019 | 05:20 PM
kanadary's Avatar
vinyl wrap
What vinyl wrap do you use?
Old Mar 27, 2019 | 05:53 PM
ramos's Avatar
try 3M Black Vinyl wrap on Amazon, lots of options
Old May 23, 2019 | 08:22 PM
Spyke's Avatar
Yep, 3M 1080 series is usually preferred
Old Jun 8, 2019 | 05:36 PM
RA092724's Avatar
Just got mine done
Old Jan 3, 2022 | 11:29 PM
  #32
j_b's Avatar
j_b
Originally Posted by dantheman1689
Couldnt help but bump this-- this looks incredible. Mine is the same color and i'm looking into doing this. Yours convinced me.
Syed Yusuf Usoppy
Nov 13, 2014 04:04 AM
ONEDVSMOFO
Aug 31, 2012 01:49 AM
hondafitblue
Jan 12, 2011 01:45 AM
mole177
Jan 5, 2011 11:34 PM
herbalteebag
Jun 5, 2009 04:34 PM
