Oil change intervals?
Old Jun 21, 2019 | 12:29 AM
Kevin8se7en's Avatar
Got a 2016 EX about 2 months ago, and it didn't come with an owner's manual. The dealership did an oil change (synthetic) just before I picked the car up, but they didn't reset the oil percentage thing in the dash. So now it's saying a need an oil change when I don't (yet).
My question is how many miles or km should I wait before doing my next oil change?
Last change was done at ~35,000km (22,000 miles). We're at 40,000km (25,000 miles) now.
Thanks
Old Jun 21, 2019 | 12:41 AM
GolNat's Avatar
7500-10000 miles for normal driving sooner if you are driving in severe conditions. I always went by the maintenance light so once it’s changed again reset it and just use that.
Some people go 5k miles.
Old Jun 21, 2019 | 12:45 AM
Brain Champagne's Avatar
Okay, so reset it now. You've gone 5000 km. See how long it takes to get to 90%, 80%, etc. Then you can figure out roughly what percentage 5000 km would be, and go from there.
Old Jun 21, 2019 | 10:05 PM
Borgus's Avatar
I do 5000 mile intervals. With that said, I've had my oil analyzed by Blackstone and they said I could go longer. 7500 would be good.
Old Jun 21, 2019 | 10:14 PM
Fuelish's Avatar
I can't comment on miles per change, as I work 3x12hr shifts per week, and work is maybe 3 miles away, if I take the long (fun) way. So, I don't rack up near 10,000 a year. I do mine once a year in the fall, probably 7000 miles-ish, I guess, at most?
Old Jun 21, 2019 | 10:34 PM
woof's Avatar
And yes, everybody has an opinion on this subject.
Old Jun 23, 2019 | 11:31 AM
Derk59RedFit's Avatar
Use Mobile 1 synthetic. You only need to change annually. To be safe every 5-7k miles. Go to YouTube to see how to reset the idiot light....its easy.
Old Jun 23, 2019 | 01:06 PM
James Butler's Avatar
2016 manuals
Here is website for 2016 fit owners manual
https://owners.honda.com/vehicle-inf...16/Fit/manuals
Old Jun 24, 2019 | 02:33 PM
LesPaulPlayer's Avatar
Yes, there is definitely a range if viewpoints on this. My non-dealer Honda specialist recommends every 5k miles because, in his opinion, the oil degrades faster than, say, cars from 10-20 years ago due to blow-by gases that get into the crankcase that leads to contaminated oil and decreased oil effectiveness...this being due to the use of piston rings in modern cars that have a low "tension" to reduce friction in an attempt to increase fuel mileage.
This blow-by-contaminated oil then gets recirculated into the combustion chamber via the Positive Crankcase Ventilation system which, combined with direct injection, increases the accumulation of deposits on the intake valves.
Mechanics can be notorious for recommending sonner-than-necessary oil changes to get an extra buck, but those reasons make sense to me.
Old Jun 24, 2019 | 02:47 PM
evilchargerfan's Avatar
add oil catch can -----> catch blow by -----> avoid excessive 5k oci -----> profit
https://www.fitfreak.net/forums/3rd-...g-edition.html
Old Jun 24, 2019 | 07:42 PM
Yeah, true. I need to get one of those. But the oil still becomes contaminated and affects it lubricating ability, right?
Old Jun 24, 2019 | 08:11 PM
GolNat's Avatar
Get it tested! Only way to know for sure.
6k miles on my carbon prone, direct injection, OEM pcv turbo engine and my oil was holding up great!
Newer cars and oils have come along way also and now run cleaner and lubricate better. Oil is cheap insurance though.
Old Jun 24, 2019 | 08:54 PM
urbie4's Avatar
We've already saved so much money by buying a Fit, that who needs to stretch the oil change interval for the sake of... what, $10-20/year? Change the oil when the light says it's time, and get on with your life, is my philosophy
Old Jun 24, 2019 | 08:58 PM
GolNat's Avatar
That was my philosophy with my Fit. Never got a chance to send a sample out but I was confident that it would have passed with flying colors.
Old Jun 25, 2019 | 09:41 AM
if youre referring to the oil in the catch can, thats a non factor as the user would regularly dump out the oil caught in the can.
who needs to stretch oil change intervals? lets hear it from the guy that drives 30k annual
assuming we all follow MM or 7500 oci, cost would be $31.65 x 4 oil changes annual = $126.60 (assuming you buy oem filters, and mobil1 from walmart). I wont bother going into state tax, since we all live in diff parts of the world. doing my oil changes at 15k, literally saves me 2x annual. I plan to keep this car for 10 yrs, thats a savings of $1266 ($1376.77 with ca tax)
$8.77 - 15400-PLM-A02 filter
Amazon Amazon
$22.88 - mobil 1 5w-20 oil
https://www.walmart.com/ip/Mobil-1-A...-5-qt/17018132
I have samples at 7500, and 10k posted in my main thread. next sample will be at 125000. after that one, I plan to do a final sample at 15k. so far, things are looking promising
FWIW, my past cars (subaru wrx and sti) both have samples at 3k, 6k, 9k and all have shown that it was perfectly safe to stretch oci's
Old Jun 25, 2019 | 10:27 AM
2Rismo2's Avatar
https://www.amazon.com/Genuine-Honda...ype=automotive
Since an oil change is 3.5 QTs, the price per oil change is lower. The oil you linked is priced at $4.576 per quart. Since you need 3.5qts for an oil change with filter, then it's $16.016 for the oil, but lets say $16 for simplicity. So really it's $24.79 + tax
Then every few containers of oil, you'll have enough left over to not even need to buy the oil I just changed mine over the weekend and this was my scenario. Just bought the oil filter! This one for less than $5!
Bosch 3323 Bosch 3323
And to stay on topic, I just use the MM. I'm getting about 8500 miles before the 15% warning comes on.
Old Jun 27, 2019 | 10:20 PM
silverrose12's Avatar
on my honda fit owner's manual, it says recommended oil is ;
API Premium-grade 0W-20 detergent oil.
but i can still use 5w-20 oil?
and what does it mean my detergent oil? i need to put my dishwasher detergent ?lol
Old Jun 28, 2019 | 09:55 AM
correction, I too am using 0w-20. I keep on saying 5w-20 .... I cant get over that bad habit. apologies for the confusion
Old Jul 4, 2019 | 10:52 AM
calafricano's Avatar
#amsoil this oil is the best out there. doesnt break down and runs super clean.
Old Jul 4, 2019 | 11:05 AM
JingJangJoe's Avatar
Hi,
Any test results to back that up?
