Flashing Gear Light - Not flashing D!
Old May 10, 2021 | 08:40 AM
polarfit's Avatar
Hello everyone! I’ve scoured the internet since this problem started last August and have found nothing similar. In my 2015 CVT when I first start the car the gear indicator will display normally for the first 10 seconds or so (steady P, or R as I leave my driveway) but will then light up with all letters and flash.
I’ve had the codes checked and nothing comes up. The transmission runs perfectly, no problems there. My AC died maybe a week before the flashing light, on the off chance they’re related. No other symptoms.
Any ideas what this could be?
Old Jun 20, 2021 | 07:20 PM
khraynor's Avatar
Same thing
The same thing is happening to me, did you ever figure out what it was?
Old Jun 21, 2021 | 09:03 AM
bargainguy's Avatar
Owner's manual, p.320:
If the transmission indicator blinks when driving, in any shift position, there is a problem with the transmission. Avoid sudden acceleration and have the transmission checked by the dealer as soon as possible.
Old Aug 29, 2021 | 05:46 AM
Daveysmith's Avatar
Hello, has anyone figure out this issue? My fit has started the same issue.
Old Jan 30, 2022 | 11:58 PM
HondaFit1335's Avatar
Wondering if anyone who responded here figured out the issue. My 2016 fit just started this.. no check engine light or OBD2 codes...
Old Jan 31, 2022 | 02:48 AM
Daveysmith's Avatar
Mine turned out to be the auto ignition. I started disangaging the auto ignition and the P/N/D stopped flashing and the engine stopped trying to switch off and on at every point I hit the breaks in traffic. After a while the auto ignition fail completely even after i stopped pressing that auto switch button. The engine runs fine without the auto ignition though.
Old Feb 13, 2022 | 01:13 PM
2015FitNJ's Avatar
Disengaging auto ignition?
Hi Daveysmith,
I've searched the internet to figure out how to disengage the auto ignition, but I haven't found anything.
My light has been flashing exactly like the OP picture.
I should have checked the coolant earlier but I checked it and it was low. Once I add more, I'll start it back up and see if it still flashes. If it does, I'd like to try what you did - could you either send me a link that describes the steps or let me know how you did it if it's a straightforward process? Many thanks! The dealership wasn't sure what it was, and my friend ran diagnostics with no codes coming up. ::fingers crossed::
Old Feb 13, 2022 | 02:15 PM
Daveysmith's Avatar
Every time When driving press this to inhibit the auto start stop which i was calling the auto ignition in my previous reply. Inhibiting this auto start stop ended my issue
Old Feb 15, 2022 | 10:53 AM
2015FitNJ's Avatar
Thank you!!!
Thank you so much for the reply!!! 👍👍👍🙌🙌🙌
Originally Posted by daveysmith
every time when driving press this to inhibit the auto start stop which i was calling the auto ignition in my previous reply. Inhibiting this auto start stop ended my issue
Old Dec 20, 2022 | 03:13 AM
Rotcel16's Avatar
any updates?
Old Apr 2, 2024 | 10:49 AM
Anjilwa's Avatar
my honda fit has the same problem and does not start nor crank
thebigr
Jul 1, 2020 10:12 AM
Dkxchill
Delaware Community
May 24, 2015 01:04 AM
Doug Just Doug
Aug 10, 2012 02:20 PM
Santiad
Oct 25, 2011 06:54 AM
wordup
May 4, 2005 11:16 AM
