Dashboard Lights
Old Mar 30, 2022 | 06:30 PM
Tfox1042's Avatar
Dashboard Lights
A month ago I replaced the front right wheel and tire. Yesterday, while driving home, the following occurred:-
The tire pressure monitoring light started flashing and then went on.
The Vehicle Stability System light went on.
The Check engine light came on.
30 seconds later the Power Steering System light came on.
There was no change to the driving characteristics or gas mileage.
The Honda service representative says that the check engine light came on because the timing change has stretched and needs to be replaced. He had no idea why the other lights came on, and didn't seem to care.
What is going on? I don't want to spend $1800 if I don't need to.
Thanks for your response,
Terry
Old Mar 30, 2022 | 10:01 PM
woof's Avatar
I really get annoyed when people post things but don't tell us what year their Fit is. And what the mileage is.
And I should I assume "timing change" is "timing chain"?
Old Mar 30, 2022 | 10:38 PM
bargainguy's Avatar
Not cutting any slack for a first post. A different approach would be to simply ask for more details without the bias. I wouldn't be surprised if the OP never came back.
Old Mar 30, 2022 | 11:16 PM
woof's Avatar
If I wanted to pull teeth I would have become a dentist. There's far too many posts where people don't give basic information wasting everybody's time. Yes I may have been short with him but I was really nice to everybody in my youth. Now I may be old and cranky - but I'm not unreasonable.
Later, after some thought In any event since an objection has been raised as to what I posted I will withdraw myself and not post any further in this thread.
Old Mar 31, 2022 | 10:09 AM
Tfox1042's Avatar
Dashboard lights
Woof. No apology is needed. I'm also getting old and cranky - and forgetful.
My FIT is a 2015, with 86,000 miles, and it does have a timing chain.
Please be patient with me, and thank you all in advance for any advice you can give me.
Terry
Old Mar 31, 2022 | 11:42 AM
2Rismo2's Avatar
If the tire geometry changed enough, it might be triggering VSC and TPMS. Try resetting your TPMS system.
Old Mar 31, 2022 | 03:01 PM
Tfox1042's Avatar
Tires are all at the correct pressure. The TPMS will not re-set.
Is it possible that a problem with the power steering/wheels and tires could cause the Check engine light to go on?
I understand that the VSS light comes on whenever the check engine light comes on.
Old Mar 31, 2022 | 10:33 PM
2Rismo2's Avatar
What do you mean it won't reset?
If you've changed out a tire, that means one tire is larger in diameter than the others because the others have lower tread depth. It might be minor, but could be enough to throw an error. The fit use the wheel speed sensor to calculate the rotations. Less inflated tires turn slower than properly inflated tires. Like a new larger tire will turn slower than more return tires.
Old Apr 1, 2022 | 09:36 AM
Tfox1042's Avatar
The tires are all at the correct pressure, but the TPMS re-calibration process does not work.
Is it possible that a failed sensor at one of the front wheels would send an error message for the TPMS, VSS and Power Steering System, triggering those lights and the Check engine light?
Terry
Old Apr 1, 2022 | 10:26 AM
2Rismo2's Avatar
Terry
Sensor could fail or get damaged. This is for a 2011, but I think it's similar to the 2015:
When you say the recalibration does not work, what do you mean by that? Sorry to keep asking, just trying to understand what you're seeing before you start having to spend money on parts and time to swap.
I was actually out at Front Royal last weekend. Didn't realize you were there till I went on a computer. Location doesn't show on a phone web interface unless you click on the person's name.
#13/14 in this diagram:
https://www.hondapartsnow.com/parts-...lower_arm.html
Old Apr 1, 2022 | 10:41 AM
Tfox1042's Avatar
The normal Re-calibration process is to push and hold the re-cal button until the TPMS light flashes. If the re-cal works, the light goes off.
On my car, when the power is turned on, the TPMS light flashes for about one minute and then stays on. The re-cal button changes nothing.
Old Apr 1, 2022 | 10:44 AM
AirborneRATT's Avatar
For the TPMS: Is it just the TPMS letters lit up or do you have the "!" with a tire icon lit? Since you have proper inflation, I'm guessing that you just have the letters for TPMS lit up. This would mean that one or more of the sensors have stopped working.
To check and clear codes, I've been using Blue Driver for the last few years and I really like it. Plugs into my OBD II port and connects to my phone or tablet. One strategy is to clear all codes and see what comes back.
Old Apr 1, 2022 | 10:53 AM
2Rismo2's Avatar
Yup my next suggestion would be to run the CEL code and see what it's saying.
The behavior you're describing with it blinking for 1m and staying on is an indicator of a fault in the system. You may just be able to turn the wheel a direction and peek to see if the wheel speed sensor looks kinked or damaged.
Why was the whole front wheel/tire replaced? Was it replaced with a similar of the other 3 wheels?
Tfox1042's Avatar
i have the Tire Icon with the "!".
Old Apr 1, 2022 | 10:58 AM
Tfox1042's Avatar
The CEL code said "stretched timing chain"
I replaced the wheel and tire because I slipped on some loose gravel and hit a rock. It gashed the tire and bent the rim. This was about a month ago. I re-calibrated the TPMS and had no problem from then until now.
Terry
Old Apr 1, 2022 | 12:28 PM
2Rismo2's Avatar
Terry
OK, TPMS is probably not a culprit if you were running a month without issue.
You're case sounds similar to this person: https://www.reddit.com/r/hondafit/co...eds_replacing/
Dillavou39
Dec 4, 2019 08:12 PM
SilverEX15
Nov 1, 2017 04:25 PM
Juliane
Jun 22, 2016 02:16 PM
mikejet
Mar 24, 2009 12:56 AM
